查看: 4043|回复: 4
[求助] 请问一下三端电阻的sub端改接什么电位
发表于 2021-8-2 09:38:02 | 显示全部楼层 |阅读模式
大家好,请问一下三端电阻的sub端该接AVDD还是AVSS有区别吗?我看前仿好像都一样,求指导,谢谢!
发表于 2021-8-2 10:30:05 | 显示全部楼层
啥类型电阻?
poly的话是没区别的。
发表于 2021-8-2 13:04:47 | 显示全部楼层
It should be "B" not "sub".
For poly resistor, both VDDA or VSSA are OK. There is a parasitic cap to "B". So if signal cross the resistor is referring to VDDA, you should connect "B" to VDDA. The same apply to VSSA
 楼主| 发表于 2021-8-2 15:48:42 | 显示全部楼层
For poly resistor, both VDDA or VSSA are OK. There is a parasitic cap t ...
感谢!
发表于 2021-8-26 17:00:46 | 显示全部楼层
看情况,如果这个电阻上的电压对sub很高,就会把电阻放在阱里,阱电位可以电阻电压比较高的一端。
GMT+8, 2025-12-29 01:46 , Processed in 0.015351 second(s), 4 queries , Gzip On, Redis On.
