查看: 3004|回复: 3
SGE安装
发表于 2021-7-15 13:29:59 | 显示全部楼层 |阅读模式
1、安装依赖:
yum install epel-release -y
yum -y install jemalloc-devel openssl-devel ncurses-devel pam-devel libXmu-devel hwloc-devel hwloc hwloc-libs java-devel javacc ant-junit libdb-devel motif-devel csh ksh xterm db4-utils perl-XML-Simple perl-Env xorg-x11-fonts-ISO8859-1-100dpi xorg-x11-fonts-ISO8859-1-75dpi gcc
2、下载并安装SGE
wget https://arc.liv.ac.uk/downloads/ ... sge-8.1.9.tar.gztar zxf sge-8.1.9.tar.gz
cd sge-8.1.9/source/
sh scripts/bootstrap.sh && ./aimk && ./aimk -man
export SGE_ROOT=/Bio/gridengine && mkdir -p $SGE_ROOT
echo Y | ./scripts/distinst -local -allall -libs -noexit
3、安装qmaster
cd $SGE_ROOT
./install_qmaster (一路回车,中间需要设置管理员账号)
4、将qmaster加入计算节点
./inst_sge -x -host c03  (一路回车)
5、验证
source $SGE_ROOT/default/common/settings.sh
执行命令:qstat -f
queuename                      qtype resv/used/tot. load_avg arch          states
all.q@c03                      BIP   0/0/2          0.16     lx-amd64
6、其他机器加入SGE机器计算节点
       需要加入计算节点的机器通过NFS挂载qmaster SGE_ROOT安装目录,建议和 SGE_ROOT的安装路径保持一致
a、在qmaster节点上
qconf -ah hostname
b、再需要添加的计算节点上
cd $SGE_ROOT
./inst_sge -x -host hostname (一路回车)
发表于 2021-7-16 02:50:52 | 显示全部楼层
Thank you for sharing
发表于 2021-7-16 13:46:30 | 显示全部楼层
good reference!!
发表于 2023-7-16 16:06:56 | 显示全部楼层
thanks
GMT+8, 2025-11-26 03:14 , Processed in 0.012726 second(s), 3 queries , Gzip On, Redis On.
