查看: 2990|回复: 1
[求助] 求助NCX的安装和配置。
发表于 2021-6-25 09:53:08 | 显示全部楼层 |阅读模式
悬赏100资产未解决
NCX2012版本,安装后,设置了如下环境变量:
setenv NCX_HOME /eda/synopsys/ncx/
set path=($NCX_HOME/bin $path)
使用NCX安装目录下的demo,产生如下的错误,请问各位大大,是安装的版本没问题,还是license问题,还是环境变量设置的问题啊?
vectorli@server:/eda/synopsys/ncx/demo/creation>./run.csh
Fri Jun 25 09:19:35 2021
                           Liberty NCX (TM)
                           Version G-2012.06-SP3
               Copyright (C) 2006-2012 Synopsys, Inc.
                          ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys, Inc
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Build date: Nov 19 2012 23:17:34
Local host: server3 Linux (2.6.32-754.el6.x86_64) (x86_64 X 96)
reading /eda/synopsys/ncx/auxx/ncx.err...done
reading run...done
getting licenses for NCX 2012.06...
  FEATURE NCX v2019.2019 in FILE 27010@server on SERVER server
done
Error: No value specified for ncx_exec (NCXCG-20)
 楼主| 发表于 2021-7-26 11:19:11 | 显示全部楼层
版本问题,更换为siliconsmart版本后,使用这个软件里面的ncx就没有问题了。
GMT+8, 2025-12-18 12:51 , Processed in 0.011325 second(s), 3 queries , Gzip On, Redis On.
