查看: 6055|回复: 15
[求助] 找書: CMOS SRAM Memory Chip Design: High Speed and Low Power
发表于 2021-5-28 00:35:24 | 显示全部楼层 |阅读模式
Author: Rajput, Sakshi
[size=1.125]Description
Static random-access memory (SRAM) continues to be a critical component across a wide range of microelectronics applications from consumer wireless to high-end workstation and microprocessor applications. For almost all fields of applications, semiconductor memory has been a key enabling technology. It is forecasted that embedded memory in SOC designs will cover up to 90% of the total chip area. A representative example is the use of cache memory in microprocessors. The operational speed could be significantly improved by the application of on-chip cache memory Semiconductor memory arrays capable of storing large quantities of digital information are essential to all digital systems. The ever-increasing demand for larger data storage capacity has driven the fabrication technology and memory development toward more compact design rules and, consequently, toward higher storage densities. This book deals with design of low power static random-access memory cells and peripheral circuits for standalone RAMs, in 350nm focusing on stable operation and reduced leakage current and power dissipation in standby and active modes.
发表于 2021-5-28 08:59:10 | 显示全部楼层
看一看就好
发表于 2021-5-28 14:23:31 | 显示全部楼层
thanks
发表于 2021-5-28 20:31:19 | 显示全部楼层
tong qiu
发表于 2021-5-29 10:41:06 | 显示全部楼层
查了下,100多页,应该是论文出版类似的。
发表于 2021-8-2 22:11:05 | 显示全部楼层
谢谢分享
发表于 2021-9-29 20:48:30 来自手机 | 显示全部楼层
Thanks
发表于 2022-10-16 13:30:52 | 显示全部楼层
好资料,感谢分享
发表于 2022-10-16 15:45:25 | 显示全部楼层
谢谢分享
发表于 2022-10-17 23:56:44 | 显示全部楼层
any update. Thanks in advance!
GMT+8, 2025-12-29 02:18 , Processed in 0.023051 second(s), 5 queries , Gzip On, Redis On.
