查看: 9770|回复: 17
siliconsmart license FEATURE SIS_BASE_CLIENT问题
发表于 2021-5-26 12:46:40 | 显示全部楼层 |阅读模式
悬赏100资产未解决
命令行运行siliconsmart出现如下错误:
PID : 5688
User: wenjfu
Dir : /home/wenjfu/.eda/workspace/test
Host: wenjfu-server
Info:    Wed May 26 11:43:51 2021: Establishing connection to license server
Error:   Wed May 26 11:43:51 2021: Unable to check out license FEATURE SIS_BASE_CLIENT
License std_client is not available. Make sure that SNPSLMD_LICENSE_FILE or LM_LICENSE_FILE has the correct license path
Info:    Maximum virtual memory size: 566.113 MB
license应该是激活了的,DC、PT、ICC2、hspice都能正常使用
我按照 https://blog.csdn.net/qq_21009513/article/details/108386854 中的方法在synopsys.src里添加了信息,最后生成的Synopsys.dat里也有SIS_*信息了,但siliconsmart还是不能运行。
lmgrd中也有SIS_*信息,如下:
11:43:17 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT2
11:43:17 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
11:43:18 (snpslmd) Server started on wenjfu-server for:        SSS
11:43:18 (snpslmd) PORT_AT_HOST_PLUS SK_sdevice-spintronics_all sdevice-parallel
11:43:18 (snpslmd) sparallel        ICWBEV_PLUS        sdevice-pathsearchtun_all
11:43:18 (snpslmd) ICCompilerII-NX ICCompilerII        ICCompilerII-NX-AdvGe
11:43:18 (snpslmd) ICCompilerII-8        ICCompilerII-8-AdvGeo SIS_ACE_BASE
11:43:18 (snpslmd) SIS_ACE_MC        SIS_ACE_MEM        SIS_BASE_CLIENT
11:43:18 (snpslmd) SIS_BASE_CM        SIS_CHAR        SIS_DFM_CLIENT
11:43:18 (snpslmd) SIS_FR                SIS_ADV                SIS_FR_CMDS
11:43:18 (snpslmd) SIS_HPX_CM        SIS_MEM_CM        SIS_SIGNOFF_CLIENT
11:43:18 (snpslmd) SIS_SIM_CLASS1        SIS_ULTRA_VALIDATION xp
11:43:18 (snpslmd) xsim                vcd2e                vcsace
11:43:18 (snpslmd) vera_comp        vera_ip                verilog_writer
11:43:18 (snpslmd) vertue                vhdl_compiler        viewlogic
 楼主| 发表于 2021-5-26 12:48:36 | 显示全部楼层
siliconsmart版本:2016.03SCL版本:11.9
crack软件:http://bbs.eetop.cn/thread-888643-1-1.html
发表于 2021-5-26 17:58:45 | 显示全部楼层
查license log 文档,是否checkcout
 楼主| 发表于 2021-5-26 19:07:42 | 显示全部楼层
没太明白诶,你说的查log文档是指这些吗? 我看不太懂啊。。。
19:03:51 ...
19:03:51 (snpslmd) Astro-Rail        AstroRailSA        AstroSpecialBeta
19:03:51 (snpslmd) AstroXtalk        Astro-Xtalk        ATMEL
19:03:51 (snpslmd) ATMWB_ATMLAYER        ATMWB_UTOPIA        AU
19:03:51 (snpslmd) AUSP                AUT_NUMBER_MAJOR_PACKAGES 3D
19:03:51 (snpslmd) 3P
19:03:51 (snpslmd)
19:03:51 (snpslmd) Licenses are case sensitive for TE_CATS
19:03:51 (snpslmd)
19:03:51 (snpslmd) EXTERNAL FILTERS are OFF
19:03:51 (lmgrd) snpslmd using TCP-port 45989
19:03:51 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  everest  extremed  hscd  innologd  ISE-TCADd  knights  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
05/26/2021 19:03:51 (snpslmd) ------------------------------------------------------------------
05/26/2021 19:03:51 (snpslmd) Checking the integrity of the license file...
05/26/2021 19:03:51 (snpslmd) Valid SSS feature found.
05/26/2021 19:03:51 (snpslmd) The feature is needed to enable the other keys in your license file.
05/26/2021 19:03:51 (snpslmd) Licensed to student@eetop
05/26/2021 19:03:51 (snpslmd) Siteid: 26356, Server Hostid: c83dd445d1a1, Issued on: 1/8/2014
19:03:52 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
19:03:52 (snpslmd) SLOG: TS update poll interval is not set.
19:03:52 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
19:03:52 (snpslmd) (@snpslmd-SLOG@) ===============================================
19:03:52 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
19:03:52 ...
发表于 2021-5-27 21:35:25 | 显示全部楼层
vcs能用不
 楼主| 发表于 2021-5-31 10:10:58 | 显示全部楼层
没装VCS。。。
 楼主| 发表于 2021-9-27 14:36:54 | 显示全部楼层
搞定了。
export SNPSLMD_LICENSE_FILE=27000@hostname
不直接指定Synopsys.dat文件路径
发表于 2021-12-30 17:51:06 | 显示全部楼层
1.我已经添加了 这些SIS_ACE_MC        SIS_ACE_MEM        SIS_BASE_CLIENT
2. lic也指定了
结果还是不行。
有大神帮忙吗?
发表于 2022-8-16 09:56:00 | 显示全部楼层
同求,又懂的吗,解决一下
发表于 2022-8-23 19:05:09 | 显示全部楼层
테스트
GMT+8, 2025-12-21 14:11 , Processed in 0.022609 second(s), 4 queries , Gzip On, Redis On.
