查看: 3380|回复: 4
[求助] ICC place报错
发表于 2021-5-20 11:55:55 | 显示全部楼层 |阅读模式
我使用的软件是icc 2018 ,使用的资料是2010年的lab guide,我在跑第一个例程也就是lab1的时候,在place_opt上报错
Information: Running stand-alone coarse placer in a separate process using temp directory '/tmp'. (PSYN-605)
Information: Executable name is '/usr/synopsys/icc/O-2018.06-SP1/linux64/syn/bin/rpsa_exec'.  (PSYN-877)
Severe Error: Fatal error: Placer did not complete. (PSYN-375)
Error: psynopt has abnormally terminated.  (OPT-100)
Error: place_opt results invalid due to placer failure.
Error: A Severe error has occurred. To ensure that the script does not continue, the value of sh_continue_on_error has been overridden to be false. Your script is being interrupted. To see the Tcl call stack for the part of your script which generated the Severe error use the error_info command.   (CMD-103)
Error: Severe error encountered
        Use error_info for more info. (CMD-013)
Information: script '/home/gz/icc_guide/IC_Compiler_2010.12-SP2/lab1_data_setup/.solutions/run.tcl'
        stopped at line 60 due to error. (CMD-081)
Extended error info:
can't unset "alo_initial_cluster": no such variable
    while executing
"unset alo_initial_cluster"
    invoked from within
"place_opt"
-- End Extended Error Info
我直接source 他自己带的run.tcl  会不会是软件错了啊,百思不得其解
请各位大佬看一下 我到底哪里出错啦
 楼主| 发表于 2021-5-20 18:35:53 | 显示全部楼层
已经找到原因 在place_opt前 加入  set_separate_process_options -placement false
发表于 2021-5-21 08:56:50 | 显示全部楼层
这个命令是干啥的
发表于 2023-4-19 18:24:18 | 显示全部楼层
学习学习
发表于 2024-8-29 15:23:30 | 显示全部楼层
遇到一樣的問題,但是這個command無效哇!!!!9命
GMT+8, 2025-12-14 15:57 , Processed in 0.017711 second(s), 4 queries , Gzip On, Redis On.
