查看: 2388|回复: 0
[求助] Quartus 工具 对casez(sel)语句,当sel大于32bit时,报错问题
发表于 2021-4-23 11:43:20 | 显示全部楼层 |阅读模式
Quartus 工具 对casez(sel)语句,当sel大于32bit时,会爆出warning,怎么解决?求助各位大牛。
always @(*)
     casez(sel[31:0])
        32'b??????????????????????????????1: a = 0;
        32'b?????????????????????????????10: a = 1;
        32'b????????????????????????????100: a = 0;
        32'b???????????????????????????1000: a = 1;
        32'b??????????????????????????10000: a = 0;
                     ......省略..................
        32'b100000000000000000000000000: a = 1;
         default: a =0;
         encase
Warning (10762): Verilog HDL Case Statement warning at **: can't check case statement for completeness because the case expression has too many possible states
2)当把sel调整为31bit,测试时,就不会报错,可以正常编译通过。
GMT+8, 2025-12-14 02:05 , Processed in 0.011277 second(s), 4 queries , Gzip On, Redis On.
