tran: time = 1.623 us (23.2 %), step = 1.653 ps (23.6 u%)
Internal error found in spectre at time = 1.6266 us during transient analysis `tran'.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
FATAL: Internal error with exception. Terminating simulation.
Error found by spectre at time = 1.6266 us during transient analysis `tran'.
ERROR (USIMUWI-20008): The simulator failed to flush the stream for the format 'psfxl'. Check the format and supporting functions (for user defined formats) before running the simulation again.no error
FATAL (SPECTRE-21): Assertion failed.
振荡器仿真过程中 每次都会在这个时间节点报错 然后跳出仿真,求问是什么原因,是软件的缘故还是结构不稳定?
