查看: 2849|回复: 4
Detection Guided NLMS Estimation of Sparsely Parametrized Channels
发表于 2007-12-10 21:37:27 | 显示全部楼层 |阅读模式
Abstract—We consider the normalized least mean square
(NLMS) estimation of a channel, which may be well approximated
by a finite impulse response model with sparsely separated
active or nonzero taps. Previously reported analyses imply that
the convergence rate of the NLMS estimator should be greatly
enhanced if only the active taps are estimated. We propose an
NLMS estimator, which incorporates a least squares based active
tap detection method. Simulations demonstrate that the NLMS
estimator has significantly faster convergence than the standard
NLMS estimator for colored as well as white input signals. Furthermore,
for sparse channels, this improved convergence speed is
accompanied by a lower computational cost.
Detection guided NLMS estimation of sparsely parametrized.pdf
121.17 KB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-4-14 00:22:21 | 显示全部楼层
thank you
发表于 2011-9-12 15:03:41 | 显示全部楼层
謝謝您的分享
发表于 2011-10-3 17:44:37 | 显示全部楼层
謝謝您的分享
发表于 2011-10-30 20:57:11 | 显示全部楼层
謝謝您的分享
GMT+8, 2025-12-14 12:05 , Processed in 0.021178 second(s), 7 queries , Gzip On, Redis On.
