查看: 19249|回复: 54
[招聘] 【招聘】【ASR】急招:ASIC Implementation Engineer
发表于 2021-3-25 15:27:18 | 显示全部楼层 |阅读模式
Job Description:
- Block, IP macro or SoC level implementation in 28nm or 16nm TSMC process
- UPF Synthesis with Synopsys DC or DCT/G flows
- Full Chip formal check on RTL2Gate and Gate2Gate with LEC and/or formality tools.
- Full Chip CLP check with CPF for nonPG and PG netlists for low power signoff.
- Working with BE team to timing closure in Primetime-SI on multi-corners and multi-modes
- Ability to build or perfect the EDA-methodology-flow with perl, tcl or shell
- Knowledge on DFT (mbist/scan) will be an added advantage
Qualifications:
- BSEE degree or above
- Strong understanding of synthesis flow using DC/DCT/DCG - for a low power (UPF) and
high speed- complex SoC
- Hands on experience with formal verification tools such as LEC and/or formality
- Must have the CTS conceptions in ICC at P&R stage
- Strong STA skills. Must have thorough knowledge on closing timing at unit and top level
- Experience in mbist and scan will be plus
- Proficient in Perl, Tcl and Shell programming
-Good team work spirit
本人非猎头!帮内推
简历发送至: 2489533094@qq.com
 楼主| 发表于 2021-3-25 16:22:52 | 显示全部楼层
 楼主| 发表于 2021-3-30 09:35:45 | 显示全部楼层
UP↑
 楼主| 发表于 2021-4-8 14:02:10 | 显示全部楼层
UPO(∩_∩)O
 楼主| 发表于 2021-4-9 16:08:30 | 显示全部楼层
UP(●'◡'●)
 楼主| 发表于 2021-4-15 16:02:51 | 显示全部楼层
UPO(∩_∩)O
 楼主| 发表于 2021-4-25 10:51:19 | 显示全部楼层
UP O(∩_∩)O
 楼主| 发表于 2021-4-26 13:26:21 | 显示全部楼层
UP O(∩_∩)O
 楼主| 发表于 2021-4-27 14:18:19 | 显示全部楼层
UP O(∩_∩)O
 楼主| 发表于 2021-4-28 14:54:52 | 显示全部楼层
UP O(∩_∩)O
GMT+8, 2025-12-24 12:39 , Processed in 0.018283 second(s), 3 queries , Gzip On, Redis On.
