楼主: open-CAD
1patch V0.3
发表于 2021-10-5 19:42:34 | 显示全部楼层
hostid future怎么填?
发表于 2021-10-8 04:53:30 | 显示全部楼层
license server启动不起来,说Invalid License File,安装是按步骤来的,env也是用的压缩包里的,大神帮忙看看是什么问题啊。系统是centos7 VMware虚拟机。
(OCAD)[rfic@tsp620 ~]$/software/ocad/tools/licsrv/bin/bin.cds/lmgrd -c /software/ocad/tools/licsrv/licenses/cds.license.dat
12:21:19 (lmgrd) -----------------------------------------------
12:21:19 (lmgrd)   Please Note:
12:21:19 (lmgrd)
12:21:19 (lmgrd)   This log is intended for debug purposes only.
12:21:19 (lmgrd)   In order to capture accurate license
12:21:19 (lmgrd)   usage data into an organized repository,
12:21:19 (lmgrd)   please enable report logging. Use Flexera's
12:21:19 (lmgrd)   software license administration  solution,
12:21:19 (lmgrd)   FlexNet Manager, to  readily gain visibility
12:21:19 (lmgrd)   into license usage data and to create
12:21:19 (lmgrd)   insightful reports on critical information like
12:21:19 (lmgrd)   license availability and usage. FlexNet Manager
12:21:19 (lmgrd)   can be fully automated to run these reports on
12:21:19 (lmgrd)   schedule and can be used to track license
12:21:19 (lmgrd)   servers and usage across a heterogeneous
12:21:19 (lmgrd)   network of servers including Windows NT, Linux
12:21:19 (lmgrd)   and UNIX.
12:21:19 (lmgrd)
12:21:19 (lmgrd)
12:21:19 (lmgrd)
12:21:19 (lmgrd) Server's System Date and Time: Thu Oct 07 2021 12:21:19 PDT
12:21:19 (lmgrd) Invalid License File
发表于 2021-10-8 10:36:34 | 显示全部楼层
Thank you for sharing them
发表于 2021-10-8 10:55:20 | 显示全部楼层
谢谢楼主!
发表于 2021-10-8 12:45:37 | 显示全部楼层
thanks
发表于 2021-10-9 16:30:27 | 显示全部楼层
after following all the steps  as given in the readme file
1.Copy this folder into windows.
2.Double click scl_keygen.exe
3.Enter your hostid and hostname.
4.click generate, you will get a Synopsys.dat file.
5.Drag it on fix.bat
my Synopsys.dat still fails the SSSverify integrity test. Do i need to process this file further for SSS line. also though it should  make no diffrence , i must mention that the drag n drop does not succeed in the windows box for me. i run fix.bat in the cmd line as > .fix.bat Synopsys.dat to fix the file.somehow the SSS line is failing the integrity test . what to do ?
发表于 2021-10-16 01:17:15 | 显示全部楼层
thanks very much!
发表于 2021-10-16 01:21:36 | 显示全部楼层
does it works with the latest Cadence tools?
发表于 2021-10-21 21:23:31 | 显示全部楼层
多谢分享
发表于 2021-11-2 15:59:01 | 显示全部楼层
楼主你好,按照你的步骤,lic可以正常启动,但软件patch后,启动很慢,需要等待几分钟,请问你遇到过这个问题吗?
GMT+8, 2025-12-17 08:01 , Processed in 0.021423 second(s), 3 queries , Gzip On, Redis On.
