查看: 23094|回复: 45
[求助] 请问大家ADE中的noise summary中的噪声类型怎么看
发表于 2021-3-13 13:50:38 | 显示全部楼层 |阅读模式
请问igs和igd是什么噪声类型呢?
发表于 2021-3-15 09:47:18 | 显示全部楼层
Ref: Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer User Guide 20.1
BSIM4:
ParameterMeaning
fn
Flicker noise
id
Thermal noise from the resistive drain current noise
rs
Source parasitic resistor thermal noise
rd
Drain parasitic resistor thermal noise
igd
Gate-to-drain tunneling current noise
igs
Gate-to-source tunneling current noise
igb
Gate-to-bulk tunneling current noise
rbdb
Resistor thermal noise between dbNode and bNode (See diagram below)
rbpb
Resistor thermal noise between bNode and bNodePrime (See diagram below)
rbpd
Resistor thermal noise between Bulk and dbNode (See diagram below)
rbps
Resistor thermal noise between bulk and bNode prime
rbsb
Resistor thermal noise between sbNode and bNode (See diagram below)
rgbi
Gate Bias-Independent Resistor thermal noise
回复 支持 37 反对 1
发表于 2022-2-21 13:39:06 | 显示全部楼层
非常感谢,找了好几天,总算有个靠谱的了
发表于 2022-6-20 22:12:37 | 显示全部楼层
加一个,rn,resistor noise,电阻热噪声类型。
回复 支持 2 反对 0
发表于 2022-6-21 09:07:35 | 显示全部楼层
远上寒杉 发表于 2021-3-15 09:47
Ref: Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer User G ...
大神~User guide可以发一下嘛,谢谢!
发表于 2022-8-17 09:34:21 | 显示全部楼层
想问一下print noise summary 的时候选的是spot noise 还是 integrated noise
 楼主| 发表于 2022-8-17 14:25:20 | 显示全部楼层
取决于你是想看单频点噪声,还是积分噪声
发表于 2022-8-18 09:29:39 | 显示全部楼层
y_potato 发表于 2022-8-17 14:25
取决于你是想看单频点噪声,还是积分噪声
如果我这边有个BG,输出噪声spec写的是0.49uV,那我应该看哪个
 楼主| 发表于 2022-8-18 09:33:01 | 显示全部楼层
是0.49uVrms?积分噪声
发表于 2022-8-18 17:46:46 | 显示全部楼层
6666
GMT+8, 2025-10-28 23:02 , Processed in 0.020323 second(s), 4 queries , Gzip On, Redis On.
