查看: 5333|回复: 21
[资料] The Fourier Transform and Its Applications
发表于 2021-2-19 12:20:54 | 显示全部楼层 |阅读模式
The Fourier Transform and Its Applications, Ronald N. Bracewell, 3rd Edition, McGraw-Hill, 2000
Preface XVll
1 Introduction 1
2 Groundwork 5
   The Fourier Transform and Fourier's Integral Theorem 5
   Conditions for the Existence of Fourier Transforms 8
   Transforms in the Limit 10
   Oddness and Evenness 11
   Significance of Oddness and Evenness 13
   Complex Conjugates 14
   Cosine and Sine Transforms 16
   Interpretation of the Formulas 18
3 Convolution 24
   Examples of Convolution 27
   Serial Products 30
   Inversion of serial multiplication / The serial product in matrix notation /
   Sequences as vectors
   Convolution by Computer 39
   The Autocorrelation Function and Pentagram Notation 40
   The Triple Correlation 45
   The Cross Correlation 46
   The Energy Spectrum 47
4 Notation for Some Useful Functions 55
   Rectangle Function of Unit Height and Base, n(x) 55
   Triangle Function of Unit Height and Area, A(x) 57
   Various Exponentials and Gaussian and Rayleigh Curves 57
   Heaviside's Unit Step Function, H(x) 61
   The Sign Function, sgn x 65
   The Filtering or Interpolating Function, sine x 65
   Pictorial Representation 68
   Summary of Special Symbols 71
5 The Impulse Symbol 74
   The Sifting Property 78
   The Sampling or Replicating Symbol III(x) 81
   The Even and Odd Impulse Pairs n(x) and II (x) 84
   Derivatives of the hnpulse Symbol 85
   Null Functions 87
   Some Functions in Two or More Dimensions 89
   The Concept of Generalized Function 92
   Particularly well-behaved functions I Regular sequences I Generalized functions I
   Algebra of generaliud functions / Differentiation of ordinary functions
6 The Basic Theorems 105
   A Few Transforms for Illustration 105
   Similarity Theorem 108
   Addition Theorem 110
   Shift Theorem 111
   Modulation Theorem 113
   Convolution Theorem 115
   Rayleigh's Theorem 119
   Power Theorem 120
   Autocorrelation Theorem 122
   Derivative Theorem 124
   Derivative of a Convolution Integral 126
   The Transform of a Generalized Function 127
   Proofs of Theorems 128
   Similarity and shift theorems / Derivative theorem / Power theorem
   Summary of Theorems 129
7 Obtaining Transforms 136
   Integration in Gosed Form 137
   Numerical Fourier Transformation 140
   The Slow Fourier Transform Program 142
   Generation of Transforms by Theorems 145
   Application of the Derivative Theorem to Segmented Functions 145
   Measurement of Spectra 147
   Radiofrequency spectral analysis / Optical Fourier transform spectroscopy
8 The Two Domains 151
   Definite Integral 152
   The First Moment 153
   Centroid 155
   Moment of Inertia (Second Moment) 156
   Moments 157
   Mean-Square Abscissa 158
   Radius of Gyration 159
   Variance  159
   Smoothness and Compactness  160
   Smoothness under Convolution  162
   Asymptotic Behavior  163
   Equivalent Width  164
   Autocorrelation Width  170
   Mean Square Widths 171
   Sampling and Replication Commute  172
   Some Inequalities  174
           Upper limits to ordinate and slope / Schwarz's inequality
   The Uncertainty Relation  177
           Proof of uncertainty relation / Example of uncertainty relation
   The Finite Difference  180
   Running Means  184
   Central Limit Theorem  186
   Summary of Correspondences in the Two Domains  191
9 Waveforms, Spectra, Filters, and Linearity 198
   Electrical Waveforms and Spectra 198
   Filters 200
   Generality of Linear Filter Theory 203
   Digital Filtering 204
   Interpretation of Theorems 205
         Similarity theorem / Addition theorem / Shift theorem / Modulation theorem /
         Converse of modulation theorem
   Linearity and TIme Invariance 209
   Periodicity 211
10 Sampling and Series 219
   Sampling Theorem 219
   Interpolation 224
   Rectangular Filtering in Frequency Domain 224
   Smoothing by Running Means 226
   Undersampling 229
   Ordinate and !5lope Sampling 230
   Interlaced Sampling 232
   Sampling in the Presence of Noise 234
   Fourier Series 235
   Gibbs phenomenon / Finite Fourier transforms / Fourier coefficients
   Impulse Trains That Pile Periodic 245
   The Shah Symbol Is Its Own Fourier Transform 246
11 The Discrete Fourier Transform and the FFT  258
   The Discrete Transform Formula  258
   Cyclic Convolution  264
   Examples of Discrete Fourier Transforms  265
   Reciprocal Property  266
   Oddness and Evenness  266
   Examples with Special Symmetry  267
   Complex Conjugates  268
   Reversal Property  268
   Addition Theorem 268
   Shift Theorem  268
   Convolution Theorem  269
   Product Theorem  269
   Cross-Correlation  270
   Autocorrelation  270
   Sum of Sequence  270
   First Value  270
   Generalized Parseval-Rayleigh Theorem  271
   Packing Theorem  271
   Similarity Theorem  272
   Examples Using MATLAB  272
   The Fast Fourier Transform  275
   Practical Considerations  278
   Is the Discrete Fourier Transform Correct?  280
   Applications of the FFT  281
   Timing Diagrams  282
   When N Is Not a Power of 2  283
   Two-Dimensional Data  284
   Power Spectra  285
12 The Discrete Hartley Transform  293
   A Strictly Reciprocal Real Transform  293
   Notation and Example  294
   The Discrete Hartley Transform  295
   Examples of DHT  297
   Discussion  298
   A Convolution of Algorithm in One and Two Dimensions  298
   Two Dimensions  299
   The Cas-Cas Transform  300
   Theorems  300
   The Discrete Sine and Cosine transforms  301
         Boundary value problems J Data compression application
   Computing  305
   Cetting a Feel for Numerical Transforms  305
   The Complex Hartley Transform  306
   Physical Aspect of the Hartley Transformation  307
   The Fast Hartley Transform  308
   The Fast Algorithm  309
   Running lime  314
   Timing via the Stripe Diagram
   Matrix Formulation
   Convolution
   Permutation
   A Fast Hartley Subroutine
13 Relatives of the Fourier Transform
   The Two-Dimensional Fourier Transform
   Two-Dimensional Convolution
   The Hankel Transform
   Fourier Kernels
   The Three-Dimensional Fourier Transform
   The Hankel Transform in n Dimensions
   The Mellin Transform
   The z Transform
   The Abel Transform
   The Radon Transform and Tomography
   The Abel-Fourier-Hnnkel ring of tmnsforrns / Projection-slice theorem /
   Reconstruction by modified back projection
   The Hilbert Transform
   The analytic signal / Instl11ztaneous frequency l11zd envelope / Causality
   Computing the Hilbert Transform
   The Fractional Fourier Transform
   Shift theorem / Derivntive theorems / Fractio1U1l convolution theorem /
   Examples of transforms
14 The Laplace Transform
   Convergence of the Laplace Integral
   Theorems for the Laplace Transform
   Transient-Response Problems
   Laplace Transform Pairs
   Natural Behavior
   Impulse Response and Transfer Function
   Initial-Value Pwblems
   Setting Out Initial-Value Problems
   Switching Problems
15 Antennas and Optics
   One-Dimensional Apertures
   Analogy with Waveforms and Spectra
   Beam Width and Aperture Width
   Beam Swinging
   Arrays of Arrays
   Interferometers
   Spectral Sensitivity Function
   Modulation Transfer Function 416
   Physical Aspects of the Angular Spectrum 417
   Two-Dimensional Theory 417
   Optical Diffraction 419
   Fresnel Diffraction 420
   Other Applications of Fourier Analysis 422
16 Applications in Statistics 428
   Distribution of a Sum 429
   Consequences of the Convolution Relation 434
   The Characteristic Function 435
   The Truncated Exponential Distribution 436
   The Poisson Distribution 438
17 Random Waveforms and Noise 446
   Discrete Representation by Random Digits 447
   Filtering a Random Input: Effect on Amplitude Distribution 450
   Digression on independence / The convolution relation
   Effect on Autocorrelation 455
   Effect on Spectrum 458
   Spectrum of random input / The output spectrum
   Some Noise Records 462
   Envelope of Bandpass Noise 465
   Detection of a Noise Waveform 466
   Measurement of Noise Power 466
18 Heat Conduction and Diffusion 475
   One-Dimensional Diffusion 475
   Gaussian Diffusion from a Point 480
   Diffusion of a Spatial Sinusoid 481
   Sinusoidal TIme Variation 485
19 Dynamic Power Spectra 489
   The Concept of Dynamic Spectrum 489
   The Dynamic Spectrograph 491
   Computing the Dynamic Power Spectrum 494
   Frequency division I Time division J Presentation
   Equivalence Theorem 497
   Envelope and Phase 498
   Using log f instead of f 499
   The Wavelet Transform 500
   Adaptive Cell Placement 502
   Elementary Chirp Signals (Chirplets) 502
   The Wigner Distribution 504
20 Tables of sinc x, sinr x, and exp ( -1Tr) 508
21 Solutions to Selected Problems 513
Chapter 2 Groundwork 513
Chapter 3 Convolution 514
Chapter 4 Notation for Some Useful Functions 516
Chapter 5 The Impulse Symbol 517
Chapter 6 The Basic Theorems 522
Chapter 7 Obtaining Transforms 524
Chapter 8 The Two Domains 526
Chapter 9 Waveforms, Spectra, Filters, and Linearity 530
Chapter 10 Sampling and Series 532
Chapter 11 The Discrete Fourier Transform and the FFf 534
Chapter 12 The Hartley Transform 537
Chapter 13 Relatives of the Fourier Transform 538
Chapter 14 The Laplace Transform 539
Chapter 15 Antennas and Optics 545
Chapter 16 Applications in Statistics 555
Chapter 17 Random Waveforms and Noise 557
Chapter 18 Heat Conduction and Diffusion 565
Chapter 19 Dynamic Spectra and Wavelets 571
22 Pictorial Dictionary of Fourier Transfonns 573
   Hartley Transforms of Some Functions without Symmetry 592
23 The Life of Joseph Fourier 594
Index 597
The Fourier Transform and Its Applications 3e.zip
17.66 MB, 下载次数: 120 , 下载积分: 资产 -6 信元, 下载支出 6 信元
发表于 2021-2-19 15:06:58 | 显示全部楼层
The Fourier Transform and Its Applications 3e.djvu, 不是pdf格式
 楼主| 发表于 2021-2-19 15:21:43 | 显示全部楼层
阅读器:http://www.djvu.org/
 楼主| 发表于 2021-2-19 16:01:26 | 显示全部楼层
发表于 2021-2-19 18:26:55 | 显示全部楼层
kankan
发表于 2021-2-19 20:11:40 | 显示全部楼层
Thank you very much.
发表于 2021-2-19 22:09:12 | 显示全部楼层
thanks
发表于 2021-2-20 07:26:24 | 显示全部楼层
谢谢分享
发表于 2021-2-20 07:41:04 | 显示全部楼层
Thanks a lot.
发表于 2021-2-20 08:06:08 | 显示全部楼层
感谢
GMT+8, 2025-12-19 10:59 , Processed in 0.021320 second(s), 4 queries , Gzip On, Redis On.
