楼主: hwhhyh25
[求助] VCS仿真卡住,无法生成verdi波形文件
 楼主| 发表于 2021-2-21 03:05:20 | 显示全部楼层
fhy420462303 发表于 2021-2-20 14:46
是不是没有加finish,没有加stop,也没有加display 。说不定都run 完了
加了finish,我在后面把tb贴出来
  1. module glitch_free_tb();
  2.         reg                clk_in0;
  3.         reg                clk_in1;
  4.         reg                clk_in2;
  5.         reg                clk_scan ;
  6.         reg                scan_dc_mode;
  7.         reg                icg_scan_mode;
  8.         reg                rst_clk_n = 0;
  9.         reg        [1:0]        cgm_sel;
  10.         initial begin
  11.         clk_in0 = 0;
  12.         clk_in1 = 0;
  13.         clk_in2 = 0;
  14.         rst_clk_n = 0;
  15.         clk_scan = 0;
  16.         icg_scan_mode = 0;
  17.         //bug: test mode is enalbe
  18.         scan_dc_mode = 0;
  19.         // solution : test mode is disable
  20.         // scan_dc_mode = 0;
  21.         # 200;
  22.         rst_clk_n = 1;
  23.         cgm_sel = 0;
  24.         repeat(50) @(posedge clk_in2);
  25.         cgm_sel = 1;
  26.         repeat(50) @(posedge clk_in2);
  27.         cgm_sel = 2;
  28.         repeat(50) @(posedge clk_in2);
  29.         icg_scan_mode =1;
  30.         scan_dc_mode = 0;
  31.         cgm_sel = 0;
  32.         repeat(1000) @(posedge clk_in0);
  33.         icg_scan_mode =0;
  34.         scan_dc_mode  =1;
  35.         cgm_sel = 2;
  36.         repeat(1000) @(posedge clk_in0);
  37.         $finish;        // finish the simulation
  38. end
  39. // dump the wave which is used for verdi
  40. initial begin
  41.         $fsdbDumpfile("glitch_free_tb.fsdb");
  42.         $fsdbDumpvars;
  43. end
  44. always #20        clk_in0 = -clk_in0;
  45. always #70        clk_in1 = -clk_in1;
  46. always #110        clk_in2 = -clk_in2;
  47. always #1000        clk_scan = -clk_scan;
  48. glitch_free u_glitch_free(
  49.         .clk_out        (clk_out),
  50.         .cgm_sel        (cgm_sel),
  51.         .clk_in0        (clk_in0),
  52.         .clk_in1        (clk_in1),
  53.         .clk_in2        (clk_in2),
  54.         .clk_scan        (clk_scan),
  55.         .rst_clk_n        (rst_clk_n),
  56.         .scan_dc_mode        (scan_dc_mode),
  57.         .icg_scan_mode        (icg_scan_mode)
  58.         );
  59. endmodule
  60.
    复制代码
发表于 2021-2-21 12:21:24 | 显示全部楼层
用 VCS 的DVE看波形不也挺好
发表于 2024-1-27 23:37:01 | 显示全部楼层
大佬,问题是怎么解决的?
发表于 2024-10-10 14:36:58 | 显示全部楼层
大佬,问题是怎么解决的?
GMT+8, 2025-9-18 08:24 , Processed in 0.012441 second(s), 3 queries , Gzip On, Redis On.
