查看: 4252|回复: 9
[求助] 请问如何在sliconsmart 中生成 PVT条件不同的库?
发表于 2021-2-8 11:32:47 | 显示全部楼层 |阅读模式
我看了相关手册,进行最简单的Pure Recharacterization Flow,
1. 无法进行基本的lab实验
按照Lab跑会卡在characterization 的stage。
Lab1_library_recharacterization
前面一切正常……
Info:    Tue Feb 02 17:53:27 CST 2021: Begin characterize stage
Information: Interrupting current command. (INT-2)
Information: One more interrupt will exit process. (INT-3)
Information: Process terminated by interrupt. (INT-4)
Info:    [CDPL] Shutting down CDPL master.
(然后整个terminal就卡死了)
2. 也跑不通自己的flow
我将文件替换成我自己的库,然后发现没有netlist,就是只有lvs的netlist。这个库有两个问题,1. 是一整个文件,不像siliconsmart要求的一个文件夹,每种module 一个模块; 2. 非常粗糙和简单,不是建库需要的包含后端参数的cdl 文件。
然后按照帖子 关于用SiliconSmart 做Re-characterization 网友的建议,我将库拆开,写了一个简单的cdl文件,然后运行就提示错误。
我拆出来的cdl文件:
.subckt AD42M2TM CO ICO S A B C D ICI VDD VSS
MN0 VSS 8 ICO VSS N_12_LPRVT w=0.3u l=0.06u
MN1 2 A VSS VSS N_12_LPRVT w=0.12u l=0.06u
MN2 VSS B 2 VSS N_12_LPRVT w=0.12u l=0.06u
MN3 31 B VSS VSS N_12_LPRVT w=0.12u l=0.06u
MP26 VDD ICI 17 VDD P_12_LPRVT w=0.20u l=0.06u
MP27 CO 20 VDD VDD P_12_LPRVT w=0.42u l=0.06u
.ends AD42M2TM
错误信息:
Info:    [CDPL] Tasks: 69/136, (50.7%, 0 Cached, 1 Failed); Active Workers: 5, Pending Workers: 0, Elapsed: 0m30s
Error:   Simulation delay__C__lh__ICO__lh__ACQ_1.sif for cell AD42M2TM failed. (SMSC-105) (AD42M2TM::delay__C__lh__ICO__lh__ACQ_1)
Error:   Bad return code (rc=32512) from 'hspice: No such file or directory' (SIM-26) (AD42M2TM::delay__C__lh__ICO__lh__ACQ_1)
Error:   Task 69 (delay__C__lh__ICO__lh__ACQ_1 of AD42M2TM) failed on W3 on server315
Error:   Simulation delay__D__lh__S__hl__ACQ_1.sif for cell AD42M2TM failed. (SMSC-105) (AD42M2TM::delay__D__lh__S__hl__ACQ_1)
Error:   Bad return code (rc=32512) from 'hspice: No such file or directory' (SIM-26) (AD42M2TM::delay__D__lh__S__hl__ACQ_1)
Error:   Task 70 (delay__D__lh__S__hl__ACQ_1 of AD42M2TM) failed on W4 on server315
……(类似的还有60多个)
Info:    [CDPL] Tasks: 136/136, (100.0%, 0 Cached, 68 Failed); Active Workers: 5, Pending Workers: 0, Elapsed: 1m00s
Info:    [CDPL] Summary:
Info:    Failed tasks:
Error:   Task 1 (modeling of AD42M2TM) failed on W1 on server315
Info:    [CDPL] Tasks: 2/2, (100.0%, 1 Failed); Active Workers: 5, Pending Workers: 0, Elapsed: 1m00s
Info:    Failed tasks:
Info:      AD42M2TM:
Info:          modeling
Info:    Merging cell level models...
 楼主| 发表于 2021-3-3 15:18:34 | 显示全部楼层
通过更换siliconsmart版本,更新license,解决如上问题之后,可以直接修改configure.tcl,即可完成相关flow。
注意到 configure.tcl 最前面的几行是:
create_operating_condition op_cond_all
add_opc_supplies op_cond_all VDD 1.2
add_opc_grounds op_cond_all VSS 0
set_opc_temperature op_cond_all 25
set_opc_process op_cond_all [subst {
        { .lib '[get_location]/../process/reference_model.lib' tt_lp_rvt12 }
只要修改对应的voltage、temperature和process即可简单重新跑库。
发表于 2021-4-19 10:43:34 | 显示全部楼层
想问一下您的问题是更换版本和license之后就解决了吗?
发表于 2021-4-19 14:51:34 | 显示全部楼层
同问,能不能贴一下您的configure.tcl的设置呢
发表于 2021-4-20 14:42:15 | 显示全部楼层
学到了!
 楼主| 发表于 2021-5-5 16:08:32 | 显示全部楼层
最后没成功,换了liberate
发表于 2021-12-31 22:22:14 | 显示全部楼层
您好,我也遇到了,生成最终的 liberty 后,就异常退出了
Segmentation fault (core dumped)
您现在找到原因了吗?我用的版本是 siliconsmart 2016
发表于 2022-10-13 10:02:35 | 显示全部楼层
食物 发表于 2021-5-5 16:08
最后没成功,换了liberate
Liberate好用吗?和SliconSmart比哪个更好些?
 楼主| 发表于 2022-10-29 22:56:45 | 显示全部楼层
逻辑差不多,但是具体命令不一样,我不知道为什么没有siliconsmart弄成功,没有合适的基准对比,不好评价
发表于 2024-4-11 11:27:43 | 显示全部楼层
假设我有一个1.8v的lib,我想生成1.2V 125c的时序lib. 我是在configure脚本开头那里设置对应的voltage为1.2、temperature 125吗?怎么设置不起作用呢?
GMT+8, 2025-12-18 05:35 , Processed in 0.018112 second(s), 3 queries , Gzip On, Redis On.
