查看: 8192|回复: 33
IEEE JOURNAL OF SOLID-STATE CIRCUITS 世界最权威的IC期刊2007年第11期
发表于 2007-12-6 12:52:40 | 显示全部楼层 |阅读模式
新鲜出炉的JSSC Volume-42  Issue-11
目录
  A 19.7 MHz, Fifth-Order Active-RC Chebyshev LPF for Draft IEEE802.11n With Automatic Quality-Factor Tuning Scheme
  A 2.5 GHz All-Digital Delay-Locked Loop in 0.13 $mu{hbox {m}}$ CMOS Technology
  Low-Power Successive Approximation Converter With 0.5 V Supply in 90 nm CMOS
  A 2.5-V 14-bit, 180-mW Cascaded $SigmaDelta$ ADC for ADSL2+ Application
  A 1.5-V 3.2 Gb/s/pin Graphic DDR4 SDRAM With Dual-Clock System, Four-Phase Input Strobing, and Low-Jitter Fully Analog DLL
  A 16-Mb Toggle MRAM With Burst Modes
  A 14-bit 200-MHz Current-Steering DAC With Switching-Sequence Post-Adjustment Calibration
  A Digitally Controlled Variable-Gain Low-Noise Amplifier With Strong Immunity to Interferers
  Stacked-Chip Implementation of On-Chip Buck Converter for Distributed Power Supply System in SiPs
  A 1.1 GHz Fifth Order Active-LC Butterworth Type Equalizing Filter
  Nonlinear Shaping SC Oscillator With Enhanced Linearity
  A 0.9 V 96 $mu$W Fully Operational Digital Hearing Aid Chip
  A Monolithic Buck Converter With Near-Optimum Reference Tracking Response Using Adaptive-Output-Feedback
  Dithering Skip Modulation, Width and Dead Time Controllers in Highly Efficient DC-DC Converters for System-On-Chip Applications
  A Sub-1-V Low-Noise Bandgap Voltage Reference
  Linear Current-Mode Active Pixel Sensor
  Sub-0.2 dB Noise Figure Wideband Room-Temperature CMOS LNA With Non-50 $Omega$ Signal-Source Impedance
  A Low Reference Spurs 1–5 GHz 0.13 $mu$m CMOS Frequency Synthesizer Using a Fully-Sampled Feed-Forward Loop Filter
  A CMOS Ultra-Wideband Receiver for Low Data-Rate Communication
  A 31.3-dBm Bulk CMOS T/R Switch Using Stacked Transistors With Sub-Design-Rule Channel Length in Floated p-Wells
  0.13-$mu$m CMOS Phase Shifters for X-, Ku-, and K-Band Phased Arrays
[ 本帖最后由 skybridge 于 2007-12-10 10:30 编辑 ]
Volume-42 Issue-11.part01.rar
4.88 MB, 下载次数: 76 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2007-12-6 12:54:13 | 显示全部楼层
PART2
Volume-42 Issue-11.part02.rar
4.88 MB, 下载次数: 68 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2007-12-6 12:56:48 | 显示全部楼层
PART3
Volume-42 Issue-11.part03.rar
4.88 MB, 下载次数: 65 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2007-12-6 13:02:41 | 显示全部楼层
PART4
Volume-42 Issue-11.part04.rar
 楼主| 发表于 2007-12-6 13:05:38 | 显示全部楼层
PART5
Volume-42 Issue-11.part05.rar
 楼主| 发表于 2007-12-6 13:11:39 | 显示全部楼层
PART6
Volume-42 Issue-11.part06.rar
4.88 MB, 下载次数: 56 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2007-12-6 13:20:04 | 显示全部楼层
PART7
Volume-42 Issue-11.part07.rar
4.88 MB, 下载次数: 60 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2007-12-6 13:26:54 | 显示全部楼层
PART8
Volume-42 Issue-11.part08.rar
 楼主| 发表于 2007-12-6 13:37:30 | 显示全部楼层
PART9
Volume-42 Issue-11.part09.rar
 楼主| 发表于 2007-12-6 13:39:53 | 显示全部楼层
PART10
Volume-42 Issue-11.part10.rar
2.71 MB, 下载次数: 63 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-12-24 11:04 , Processed in 0.026317 second(s), 8 queries , Gzip On, Redis On.
