查看: 2670|回复: 9
spectre20 cannot work
发表于 2021-1-27 13:43:58 | 显示全部楼层 |阅读模式
Hi
spectre20 can not work by troditional crack method(open-cad provided )
who could help to solve this problem?
thanks a lot
发表于 2021-1-27 16:06:26 | 显示全部楼层
i can try but need to get spectre20 for test. can you share it?
发表于 2021-1-27 16:35:02 | 显示全部楼层
I tested, spectre20 works normal.
 楼主| 发表于 2021-1-27 16:45:45 | 显示全部楼层
What linux version you use in spectre20? RHEL7.6 ?thanks a lot
发表于 2021-1-27 16:48:59 | 显示全部楼层
redhat6 and redaht7 works fine.
发表于 2021-1-27 17:11:51 | 显示全部楼层
redhat 6、7、8应该都好用。所以大家需要的是安装包...然后你把问题现象或者log文件贴出来,问题自然解决了。
发表于 2021-2-3 18:33:19 | 显示全部楼层
21年新出了hotfix, 你是说这个不工作?
 楼主| 发表于 2021-2-10 21:58:02 | 显示全部楼层
yes
发表于 2021-2-13 10:02:51 | 显示全部楼层
求分享,谢谢!
发表于 2021-2-26 15:59:54 | 显示全部楼层
求安装包
GMT+8, 2025-12-20 21:16 , Processed in 0.017949 second(s), 3 queries , Gzip On, Redis On.
