查看: 3241|回复: 8
[原创] FPGA矿机,比特币
发表于 2020-12-28 12:33:00 | 显示全部楼层 |阅读模式
有对FPGA矿机挖矿感兴趣的吗,抱着强烈想要做一番事的同仁,留言。
发表于 2020-12-28 14:25:50 | 显示全部楼层
没有,谢谢
发表于 2020-12-28 17:13:16 | 显示全部楼层
7nm的ASIC矿机都出来了,FPGA没有优势
发表于 2020-12-30 15:07:59 | 显示全部楼层
对于频繁改算法的小币种ASCI不敢冒这个风险,fpga由于灵活性反而有优势
发表于 2020-12-31 02:48:36 | 显示全部楼层
If you use an Alveo 250, wich contain 1300000 LUT, as a SHA256 hash need about 1300LUT and 65 cycle, if your alveo is at 500MHz you will reach 6.7Ghash/s <1USD/day (alveo 250 is more than 1USD/hour on amazon).
An ASIC can do 110Thash/sec.
Even if you can optimize the sha256 algorithm, you will never can win money with fpga...
发表于 2021-1-6 07:28:16 | 显示全部楼层
To those who thinks ASIC has a chance, they should know that in the end the speed is limited by the Source Synchronous communication (PCIE) between the main processor and any hardware accelerators (AISC,GPU, FPGA, etc). So speed of the ASIC won't benefit that much.
See the Jungle, not the trees
发表于 2021-1-7 08:46:24 | 显示全部楼层
差点被一家投行公司挖去管理FPGA挖币项目,作为一枚小小的FPGAer,完全懵逼,没这个实力,果断拒了这个offer,不然现在还不知道命运几何。
发表于 2021-1-7 09:14:22 | 显示全部楼层
努力工作赚钱 比较实在, bitcoin 就跟炒楼一样 , 你不会知 何时会翻   , 总有最后一只老鼠..
发表于 2021-1-7 11:38:18 | 显示全部楼层
现在还有矿可挖么?
GMT+8, 2025-12-23 11:21 , Processed in 0.018755 second(s), 5 queries , Gzip On, Redis On.
