查看: 3825|回复: 2
[求助] 调用器件时会出现警告,怎么回事?
发表于 2020-12-25 10:45:31 | 显示全部楼层 |阅读模式
调用器件时,会出现警告:*WARNING* ddMapGetFileViewType: You are trying to run a CDB executable on an OA library file 'sch.oa'. The file is in library 'rfExamples' in cell 'image_reject_rcvr_PB' in view 'schematic'. You must run an OA executable to use that library file.是怎么回事?
发表于 2020-12-25 11:45:00 | 显示全部楼层
数据格式不对。用IC6去打开调用这个库,或者换cdb格式的lib。
 楼主| 发表于 2020-12-25 17:49:54 | 显示全部楼层
谢谢大家。
GMT+8, 2025-12-19 02:33 , Processed in 0.012188 second(s), 3 queries , Gzip On, Redis On.
