查看: 2624|回复: 5
IC616出现错误,求解决!
发表于 2020-12-23 15:38:30 | 显示全部楼层 |阅读模式
悬赏100资产未解决
启动virtuoso&  出现错误提示
WARNING* envSetVal: Can't set the value of variable 'devType',
    in tool[.partition] 'layout' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer1Direction',
*WARNING* envSetVal: Can't set the value of variable 'alignViaEdgeWithWire',
*WARNING* envSetVal: Can't set the value of variable 'contactWidth',
*WARNING* envSetVal: Can't set the value of variable 'pinInstLibName',
*WARNING* envSetVal: Can't set the value of variable 'matchWireWidth',
*WARNING* envCyclicStringToIndex: could not find variable 'matchTargetPinWidthValue'
*WARNING* envSetVal: Can't set the value of variable 'matchTargetPinWidthValue',
*WARNING* envSetVal: Can't set the value of variable 'routeSpec',
*WARNING* envSetVal: Can't set the value of variable 'pinsAreSymbolic',
*WARNING* envSetVal: Can't set the value of variable 'useDisplayGrid',
*WARNING* envSetVal: Can't set the value of variable 'autoContact',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer1YEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'matchPinWidth',
*WARNING* envSetVal: Can't set the value of variable 'autoInstPin',
*WARNING* envSetVal: Can't set the value of variable 'contactRows',
*WARNING* envSetVal: Can't set the value of variable 'useDefaultVia',
*WARNING* envCyclicStringToIndex: could not find variable 'routeStatus'
*WARNING* envSetVal: Can't set the value of variable 'routeStatus',
*WARNING* envSetVal: Can't set the value of variable 'shapeInfoOn',
*WARNING* envSetVal: Can't set the value of variable 'checkPreferLayers',
*WARNING* envCyclicStringToIndex: could not find variable 'routeTopology'
*WARNING* envSetVal: Can't set the value of variable 'routeTopology',
*WARNING* envSetVal: Can't set the value of variable 'contactDelX',
*WARNING* envSetVal: Can't set the value of variable 'userVia',
*WARNING* envSetVal: Can't set the value of variable 'gatherBusWires',
*WARNING* envSetVal: Can't set the value of variable 'routePurpose',
*WARNING* envCyclicStringToIndex: could not find variable 'matchPinWidthValue'
*WARNING* envSetVal: Can't set the value of variable 'matchPinWidthValue',
*WARNING* envSetVal: Can't set the value of variable 'contactColumns',
*WARNING* envSetVal: Can't set the value of variable 'alignApplySpacings',
*WARNING* envSetVal: Can't set the value of variable 'devClass',
*WARNING* envCyclicStringToIndex: could not find variable 'contactJustify'
*WARNING* envSetVal: Can't set the value of variable 'contactJustify',
*WARNING* envSetVal: Can't set the value of variable 'contactLength',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer2YEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'alignSeparation',
*WARNING* envSetVal: Can't set the value of variable 'contactDelY',
*WARNING* envSetVal: type mismatch for variable 'alignMethod'
    in tool[.partition] 'layout'.
*WARNING* envSetVal: Can't set the value of variable 'layerTapCycle',
*WARNING* envSetVal: Can't set the value of variable 'routeType',
*WARNING* envSetVal: cyclic value for variable 'viaPattern'
    is out of the choice range 0..8.
*WARNING* envSetVal: Can't set the value of variable 'pinType',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaXcutSpacing',
*WARNING* envSetVal: Can't set the value of variable 'enableBusRouting',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer2XEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'contactInstLibName',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaStackedVias',
*WARNING* envSetVal: cyclic value for variable 'busWireSpacingType'
    is out of the choice range 0..4.
*WARNING* envSetVal: Can't set the value of variable 'contactName',
*WARNING* envSetVal: Can't set the value of variable 'matchTargetPinWidth',
*WARNING* envSetVal: Can't set the value of variable 'alignApplySeparation',
*WARNING* envSetVal: Can't set the value of variable 'alignSelectionMode',
*WARNING* envSetVal: Can't set the value of variable 'pinLength',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer1XEnclosure',
*WARNING* envSetVal: Can't set the value of variable 'matchWidthSticky',
*WARNING* envSetVal: Can't set the value of variable 'cdsViaLayer2Direction',
*WARNING* envSetVal: Can't set the value of variable 'initBoundaryLayer',
    in tool[.partition] 'layoutXL' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'ignoreNames',
*WARNING* envSetVal: Can't set the value of variable 'checkTimeStamps',
*WARNING* envSetVal: Can't set the value of variable 'pathSwitchPurpose',
*WARNING* envSetVal: Can't set the value of variable 'dlrNetConstNetWeight',
*WARNING* envSetVal: Can't set the value of variable 'templateFileName',
*WARNING* envSetVal: Can't set the value of variable 'sfactorParam',
*WARNING* envSetVal: Can't set the value of variable 'pathProbe',
*WARNING* envSetVal: Can't set the value of variable 'pathSwitchLayer',
*WARNING* envSetVal: Can't set the value of variable 'initIOPinName',
*WARNING* envSetVal: Can't set the value of variable 'ignoredParams',
*WARNING* envSetVal: Can't set the value of variable 'vxlDebugLogFileName',
*WARNING* envSetVal: Can't set the value of variable 'initSymbolicPins',
*WARNING* envSetVal: Can't set the value of variable 'showIncNetEnable',
*WARNING* envSetVal: Can't set the value of variable 'pathPurposeList',
*WARNING* envSetVal: Can't set the value of variable 'dlrRoutingBoundaryOption',
*WARNING* envSetVal: Can't set the value of variable 'dlrNetConstNetClass',
*WARNING* envSetVal: Can't set the value of variable 'vxlDebugLog',
*WARNING* envSetVal: Can't set the value of variable 'incNetCycleHilite',
*WARNING* envSetVal: cyclic value for variable 'showFixedMenu'
    is out of the choice range 0..3.
新建cel lview 的时候又提示新的错误:
*WARNING* (DEBASE-102079): A SKILL error occurred in function schMenuTrigger
*Error* append: argument #2 should be a list - t
另一个服务器上的615  没问题 ,都是在centos 5.9 上运行,怎么解决,求大神指导!
发表于 2020-12-23 16:34:41 | 显示全部楼层
路过学习,很实用,学习分享。
发表于 2020-12-23 17:21:13 | 显示全部楼层
l13787908861 发表于 2020-12-23 16:34
路过学习,很实用,学习分享。
每次路过,不合适吧。
发表于 2020-12-23 17:45:03 | 显示全部楼层
joycechou1110 发表于 2020-12-23 17:21
每次路过,不合适吧。
刷积分的,是个帖子都顶...
发表于 2023-3-16 14:29:49 | 显示全部楼层
怎么样,解决了,同样问题
 楼主| 发表于 2023-3-29 13:59:31 | 显示全部楼层
wangluo 发表于 2023-3-16 14:29
怎么样,解决了,同样问题
换版本617721 了
GMT+8, 2025-12-25 23:09 , Processed in 0.023521 second(s), 4 queries , Gzip On, Redis On.
