查看: 4588|回复: 3
[求助] IC617从原理图调入元器件到版图
发表于 2020-10-31 15:07:06 | 显示全部楼层 |阅读模式
悬赏5资产未解决
请假大家,我用connectivity-generate-all from source调入元器件时,报了下面的错,且我用shift+f打不开所有层。
Technology 'cdsDefTechLib' does not have a constraint group named 'virtuosoDefaultExtractorSetup'. Thus the XL connectivity extractor is disabled. To enable it, add a 'validLayers' constraint to the appropriate constraint group, and ensure that this constraint group is specified by the 'setupConstraintGroup' environment variable.
发表于 2020-10-31 16:37:05 | 显示全部楼层
你attach的是这个cdsDefTechLib库?
发表于 2020-11-2 17:51:20 | 显示全部楼层
你搭建电路的这个库没有attach工艺库,看看你的工艺库是哪个,然后attach一下就好了
发表于 2020-11-4 10:28:42 | 显示全部楼层
有工艺库就关联工艺库,没有就关联相应的Techfile
GMT+8, 2025-12-22 10:36 , Processed in 0.727767 second(s), 5 queries , Gzip On, Redis On.
