查看: 7485|回复: 7
[资料] Using Artificial Neural Networks for Analog Integrated Circuit Design Automation
发表于 2020-10-13 21:39:11 | 显示全部楼层 |阅读模式
Author(s): João P. S. Rosa, Daniel J. D. Guerra, Nuno C. G. Horta, Ricardo M. F. Martins, Nuno C. C. Lourenço
Series: SpringerBriefs in Applied Sciences and Technology
Publisher: Springer International Publishing, Year: 2020
ISBN: 978-3-030-35742-9,978-3-030-35743-6
Introduction[size=1.7]This book addresses the automatic sizing and layout of analog  integrated circuits (ICs) using deep learning (DL) and artificial neural networks (ANN). It explores an innovative approach to automatic circuit sizing where ANNs learn patterns from previously optimized design solutions. In opposition to classical optimization-based sizing strategies, where computational intelligence techniques are used to iterate over the map from devices’ sizes to circuits’ performances provided by design equations or circuit simulations, ANNs are shown to be capable of solving analog IC sizing as a direct map from specifications to the devices’ sizes. Two separate ANN architectures are proposed: a Regression-only model and a Classification and Regression model. The goal of the Regression-only model is to learn design patterns from the studied circuits, using circuit’s performances as input features and devices’ sizes as target outputs. This model can size a circuit given its specifications for a single topology. The Classification and Regression model has the same capabilities of the previous model, but it can also select the most appropriate circuit topology and its respective sizing given the target specification. The proposed methodology was implemented and tested on two analog circuit topologies.
Keywords[size=1.7]Analog IC sizingArtificial Neural NetworksAnalog IC PlacementElectronic Design AutomationApplied Deep LearningAnalog IC Design Automation
(SpringerBriefs in Applied Sciences and Technology) João P. S. Rosa, Daniel J. .pdf
3.26 MB, 下载次数: 96 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2020-10-14 20:01:05 | 显示全部楼层
thanks
发表于 2020-10-16 13:12:06 | 显示全部楼层
Good one for download
发表于 2020-10-17 09:43:17 | 显示全部楼层
模拟ic工程师要被干掉了?
发表于 2020-10-19 13:43:01 | 显示全部楼层
thanks!!!
发表于 2020-10-19 15:12:00 | 显示全部楼层
学习了,多谢楼主。
发表于 2025-1-22 00:29:28 | 显示全部楼层
xie xie !
发表于 2025-1-22 07:11:56 | 显示全部楼层
Thanks!!!!
GMT+8, 2025-11-12 19:12 , Processed in 0.022685 second(s), 4 queries , Gzip On, Redis On.
