查看: 15221|回复: 58
[资料] [Spring 2018] Energy-Efficient Smart Temperature Sensors in CMOS Technology
发表于 2020-9-11 10:54:11 | 显示全部楼层 |阅读模式
Introduction
This book describes the design and implementation of energy-efficient smart (digital output) temperature sensors in CMOS technology. To accomplish this, a new readout topology, namely the zoom-ADC, is presented. It combines a coarse SAR-ADC with a fine Sigma-Delta (SD) ADC. The digital result obtained from the coarse ADC is used to set the reference levels of the SD-ADC, thereby zooming its full-scale range into a small region around the input signal. This technique considerably reduces the SD-ADC’s full-scale range, and notably relaxes the number of clock cycles needed for a given resolution, as well as the DC-gain and swing of the loop-filter. Both conversion time and power-efficiency can be improved, which results in a substantial improvement in energy-efficiency. Two BJT-based sensor prototypes based on 1st-order and 2nd-order zoom-ADCs are presented. They both achieve inaccuracies of less than ±0.2°C over the military temperature range (-55°C to 125°C). A prototype capable of sensing temperatures up to 200°C is also presented. As an alternative to BJTs, sensors based on dynamic threshold MOSTs (DTMOSTs) are also presented. It is shown that DTMOSTs are capable of achieving low inaccuracy (±0.4°C over the military temperature range) as well as sub-1V operation, making them well suited for use in modern CMOS processes.
Presents a new readout technique (the zoom-ADC) to address the implementation of energy-efficient temperature sensors in CMOS technology;
Shows how this technique can be used to design energy-efficient temperature sensors without compromising other key specifications, such as accuracy and resolution;
Shows how this technique can be used to design general-purpose incremental ADCs that can achieve both high resolution and state-of-the-art energy efficiency;
Presents DTMOST-based temperature sensors, which achieve significantly higher accuracy than previous all-CMOS temperature sensors.
Keywords
Energy-Efficient Temperature Sensors
Incremental Analog to Digital converters
energy efficient ADCs
sensor interfaces in CMOS technology
zoom-ADCs
Energy-Efficient Smart Temperature Sensors in CMOS Technology.pdf
4.05 MB, 下载次数: 592 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2020-9-11 14:37:25 | 显示全部楼层
good thx !!!!!!!!!!!!!!!
发表于 2020-9-11 19:23:50 | 显示全部楼层
thanks
发表于 2020-9-12 01:19:59 | 显示全部楼层
Thanks!!!
发表于 2020-9-12 08:17:51 | 显示全部楼层
Thanks
发表于 2020-9-12 08:25:45 | 显示全部楼层
感谢
发表于 2020-9-12 08:40:06 | 显示全部楼层
谢谢分享
发表于 2020-9-12 08:45:30 | 显示全部楼层
多谢分享
发表于 2020-9-13 06:29:35 | 显示全部楼层
Thanks for the share
发表于 2020-9-16 17:56:31 | 显示全部楼层
thank you!
GMT+8, 2025-12-24 21:28 , Processed in 0.021167 second(s), 5 queries , Gzip On, Redis On.
