查看: 2172|回复: 2
[求助] ic618启动卡死 有大神知道怎么回事吗
发表于 2020-8-12 15:06:15 | 显示全部楼层 |阅读模式
我启动618,输入命令后窗口弹出后卡死,log如下 有知道是什么问题的吗?
\# Program start time:     UTC 2020.08.12 14:39:28.980
\# Local time: CST (UTC+08:00) 2020.08.12 22:39:28.980
\o Program:                @(#)$CDS: virtuoso version 6.1.8-64b 10/01/2018 20:02 (ip-172-18-22-57) $
\o Hierarchy:                /home/cad/layout/ic618/IC618/tools.lnx86/dfII/
\o Sub version:                sub-version  IC6.1.8-64b.83  (64-bit addresses)
\# Command line:        /home/cad/layout/ic618/IC618/tools/dfII/bin/64bit/virtuoso
\# Host name (type):        ep107 (x86_64)
\# Operating system:        Linux 3.10.0-957.el7.x86_64 #1 SMP Thu Nov 8 23:39:32 UTC 2018
\# Linux /etc/issue:        \S
\# Linux /etc/issue:        Kernel \r on an \m
\# X display name (WxH):        localhost:11.0 (1674x992)
\# AvAIlable geometry:                        TL(0:25) BR(1673:966)
\# X server:                        The X.Org Foundation
\# Depth of Visual (Root):        24 (24)
\# Number of Planes Used:        24
\# X version:                11.0 (vendor release 70000000)
\# X resource pool:        base 0x3c00000, mask 0x1fffff (2097151), shift 0
\#                         current id 0x0, current max 0x1ffffa (2097146)
\# Max data seg size:             unlimited
\# Max process size:             unlimited
\# Initial sbrk value:                498 MB
\# Available memory:            255,740 MB
\# System memory:            261,364 MB
\# Maximum memory size:            261,128 MB
\# Max mem available:            256,003 MB
\# Initial memory used:                263 MB
\#        process size:              1,466 MB
\# Thread usage limits (effective/default):        maxthreads 4096/4096 maxload 64.00/64.00
\# Qt version:                5.9.1
\# Window Manager:        gnome (metacity)
\# User Name:                user
\o Working Directory:        ep107:/home/user
\# Process Id:                39777
\o
\o COPYRIGHT (C) 1992-2018  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           (C) 1992-2018  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\o Qt Debug Message: QFactoryLoader:FactoryLoader() checking directory path "/home/cad/layout/ic618/IC618/tools.lnx86/Qt/v5/64bit/plugins/accessible" ...
\o Qt Debug Message: QFactoryLoader:FactoryLoader() checking directory path "/home/cad/layout/ic618/IC618/tools.lnx86/dfII/bin/64bit/accessible" ...
\w Qt Warning: QXcbConnection: XCB error: 173 (Unknown), sequence: 172, resource id: 87, major code: 150 (Unknown), minor code: 20
\w *WARNING* envSetVal: value for integer variable 'matlabExprReevalSearchUpdateLevel'
\w         is below minimum range value 1.
\w *WARNING* envSetVal: value for integer variable 'maxR2PercentOMP'
\w         is below minimum range value 80.
\# Memory report: using         446 MB, process size 1,658 MB at UTC 2020.08.12 14:39:35.829
\# Available memory:        255,679 MB at UTC 2020.08.12 14:39:39.281
运行到这就不动了
 楼主| 发表于 2020-8-12 15:08:13 | 显示全部楼层
我看正常下面改运行这些了
\# Available memory:        249,581 MB at UTC 2020.08.11 16:49:01.335
\# Memory report: Maximum memory size now 250,076 MB at UTC 2020.08.11 16:49:01.336
\# Thread usage report: 67 active threads, active load 1.00 at UTC 2020.08.11 16:49:01.336
\o Loading geView.cxt
\o Loading menuBuilder.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading wireEdit.cxt
\o Loading pte2.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o Loading layers.cxt
发表于 2021-6-3 10:26:30 | 显示全部楼层
你好!有解决吗?
GMT+8, 2025-10-25 00:18 , Processed in 0.016766 second(s), 4 queries , Gzip On, Redis On.
