查看: 2127|回复: 4
HSPICE 求助
发表于 2020-7-29 10:15:51 | 显示全部楼层 |阅读模式
edsp  vdp  0  vdn  0  -1 $ reflect drain voltage
请问这个函数怎么解释啊,谢谢
发表于 2020-7-30 22:30:54 | 显示全部楼层
不是函数,压控电压源罢了
 楼主| 发表于 2020-8-3 11:20:42 | 显示全部楼层
test_123 发表于 2020-7-30 22:30
不是函数,压控电压源罢了
怎么解释呢??
发表于 2020-8-3 11:41:31 | 显示全部楼层
volt control source
output vdp
in  vdn
vdp = - vdn
HSPICE
Linear
Exxx n+ n- [VCVS] in+ in- gain [MAX=val] [MIN=val]
+ [SCALE=val] [TC1=val] [TC2=val] [ABS=1] [IC=val]
Polynomial (POLY)
Exxx n+ n- [VCVS] POLY(NDIM) in1+ in1- ...
+ inndim+ inndim-TC1=val [TC2=val] [SCALE=val]
+ [MAX=val] [MIN=val] [ABS=1] p0 p1… [IC=val]
Piecewise Linear (PWL)
Exxx n+ n- [VCVS] PWL(1) in+ in- [DELTA=val]
+ [SCALE=val] [TC1=val] [TC2=val] x1,y1 x2,y2 ...
+ x100,y100 [IC=val]
 楼主| 发表于 2020-8-26 16:00:45 | 显示全部楼层
andy2000a 发表于 2020-8-3 11:41
volt control source
output vdp
谢谢~~~
GMT+8, 2025-12-25 18:49 , Processed in 0.014726 second(s), 6 queries , Gzip On, Redis On.
