查看: 10709|回复: 20
[求助] smic 28nm怎么安装?
发表于 2020-7-25 01:07:35 | 显示全部楼层 |阅读模式
小白一个,刚刚装好cadence ic617,然后有个这样的文件,也不是论坛里的PDK,好像也是工艺库,这需要咋安装啊。
有没有大佬给小弟看看这个文件是干啥的,是怎么安装的 谢谢!!!
是不是要解压啊
发表于 2020-7-25 02:56:37 | 显示全部楼层
These not PDK: they are standard cell libraries.PDK is for cadence IC package, to design with devices, scgematic and layout and verifications.
Standard cell libraries are for place and route of digital designs.
发表于 2020-7-25 02:58:22 | 显示全部楼层
smn1380 发表于 2020-7-25 02:56
These not PDK: they are standard cell libraries.PDK is for cadence IC package, to design with device ...
To install them , just unzip and untar them.
But you will need digital tools linke cadence innovus or genus or synopsys dc and icc tools to work with them.
发表于 2020-7-25 10:11:26 | 显示全部楼层
这是arm的数字库,  virtuoso用不了,要找pdk
 楼主| 发表于 2020-7-25 10:28:15 | 显示全部楼层
你好这个arm数字库需要什么软件能用呢? 我没有28nm的pdk阿
 楼主| 发表于 2020-7-25 10:30:06 | 显示全部楼层
But you will need digital tools linke cadence innovus ...
THANK YOU!
 楼主| 发表于 2020-7-25 10:32:32 | 显示全部楼层
大佬 能不能简单的说下数字库的作用吗,导师出差了,让我安装这些东西,我搞不明白
发表于 2020-7-25 11:37:26 | 显示全部楼层
mark...
发表于 2020-7-25 21:04:26 | 显示全部楼层
Digital Library are used for digital circuit design.
Digital design is written to VHDL/Verilog code, then using the stdcells in these libraries, it is  syntheisze. to gates.
Then converted to digital layout.
For installing these libraries there should be (install) script that simply untar and unrar these files to a given folder.
 楼主| 发表于 2020-7-28 00:01:23 | 显示全部楼层
Digital design is written to VHDL/Verilog cod ...
谢谢您
GMT+8, 2025-12-14 15:57 , Processed in 0.023663 second(s), 4 queries , Gzip On, Redis On.
