查看: 2602|回复: 1
IC5141打不开
发表于 2020-7-20 14:27:02 | 显示全部楼层 |阅读模式
打开后直接闪退,cds.log如下,请高手帮忙解决,谢谢
\o Program:             @(#)$CDS: icfb.exe version 5.1.0 09/12/2006 22:50 (cicln03) $
\o Hierarchy:           /eda/cadence/IC5141/IC5141USR4/tools.lnx86/dfII/
\o Sub version:         sub-version 5.10.41_USR4.54.77 (32-bit addresses)
\o Host name (type):    localhost.localdomain (x86_64)
\o Operating system:    Linux 3.10.0-1127.13.1.el7.x86_64 #1 SMP Tue Jun 23 15:46:38 UTC 2020
\o X display name:      :2
\o X server:            The X.Org Foundation
\o Depth of Visual (Root):      24 (24)
\o Number of Planes Used:       24
\o X version:           11.0 (vendor release 12004000)
\o Window Manager:      other
\o User Name:           zhangfeng
\o Working Directory:   localhost.localdomain:/home/zhangfeng/layout
\o Process Id:          190998
\o
\o COPYRIGHT ?1992-2005  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           ?1992-2005  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\p >
\o 8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
\w *WARNING* (infile): not a normal file - /eda/cadence/IC5141/IC5141USR4/tools.lnx86/dfII/etc/tools/cdba/.cdsenv
\e *Error* rplacd: first arg must not be nil - nil
\w *WARNING* (infile): not a normal file - /eda/cadence/IC5141/IC5141USR4/tools.lnx86/dfII/etc/tools/graphic/.cdsenv
 楼主| 发表于 2020-7-23 18:17:27 | 显示全部楼层
GMT+8, 2025-12-27 07:45 , Processed in 0.012483 second(s), 3 queries , Gzip On, Redis On.
