楼主: suha123456
[求助] 想问问各位这是自己搭的bandgap电路,有实用价值吗,是不是太简单了
发表于 2020-7-5 05:54:51 | 显示全部楼层
A few things about the circuit:
It is an ok topology if you do not have a bipolar transistor where the collector only connects to a supply (ground here). By putting the amplifier across the delta_Vbe you create an offset which is gained up something like 10x to the bandgap (54mV to 500mV-ish). To make matters worse, the offset is not PTAT. Thus if you trim it out using the PTAT trim you will have a bandgap that looks great at 25C but has attrocious temperature drift.
If you do have the abillity to tie the collectors to another node consider a gained up brokaw cell. It is easy and performs much better.
As someone else mentioned the capacitor location is problematic. One end is to the bandgap and the other is to 1 diode below the power supply. That will wreck your PSRR. Nearly identical (possibly better) stability can be achieved by instead tying it between Vbg and the cascode node 1 NMOS down from the node it is tied to now. It is still a miller cap when tied that way. The RHP zero is pushed out dramatically though because that cascode node is relatively low impedance. Also that node is ground referenced so that ripple on the power supply will not automatically exist there.
Cheers,
REF
回复 支持 2 反对 0
发表于 2020-7-7 17:37:21 | 显示全部楼层
实用的过程中 应该会加一点可调节的功能
发表于 2020-7-7 17:56:37 | 显示全部楼层
虎大王 发表于 2020-7-3 20:01
电路就是书上那些稍微改了下,其实书上那些原封不动都是很有实用价值的,你改动的话,你要明白你为啥要这 ...
做产品的东西都是越简单越好,如果要高精度,就去trim。写论文啥的需要些花里胡哨的东西,估计就改来改去的。研究下没啥大不了,总要有自己的想法。
发表于 2021-4-26 23:55:42 | 显示全部楼层
感觉这是chris课上的啊
发表于 2021-9-9 16:59:30 | 显示全部楼层
把chris课程的电路讲解例子拿出来就说自己搭的,兄弟,真的自己搭一个再来提问吧
发表于 2021-9-24 22:58:35 | 显示全部楼层
呵呵,和chris课上的bandgap一模一样,miller电容会减小PSRR零点的位置,楼上说的没错可以用间接补偿改善PSRR
发表于 2022-4-15 22:24:13 | 显示全部楼层
这不就是Chris的视频里的吗
GMT+8, 2025-12-31 00:40 , Processed in 0.016994 second(s), 6 queries , Gzip On, Redis On.
