楼主: wuende
[原创] Multiband Dual-Function CMOS RFIC Filter-Switches.Springer.2020
发表于 2020-6-14 17:43:10 | 显示全部楼层
good topic
thank you
发表于 2020-6-14 19:07:22 | 显示全部楼层
下载看看
发表于 2020-6-15 16:59:30 | 显示全部楼层
Typical RF switches are designed only for switching purposes without considering frequency selectivity or filtering. A separate filter is normally used with a switch
to provide a filtering function. For instance, a band-pass filter is typically needed
between the antenna and transmit/receive (T/R) switch to suppress unwanted signals arriving from the antenna before going to the receiver’s low-noise amplifier (for
receiving) and coming out of the transmitter’s power amplifier before reaching the
antenna (for transmitting). This conventional design approach leads to higher insertion loss, larger size and higher cost for RF systems. To overcome these problems, it
is logical to combine filter and switching functions in the design to produce a single
circuit that is capable of simultaneous switching and filtering, while keeping the size
comparable to that of a corresponding switch without filtering capability.
发表于 2020-6-15 18:06:31 | 显示全部楼层
资料不错,多谢分享
发表于 2020-6-19 10:47:40 | 显示全部楼层
发表于 2020-6-20 22:37:18 | 显示全部楼层
我为啥下不了呢
发表于 2020-6-20 22:47:54 | 显示全部楼层
还等等好几天才能看呢.................
发表于 2020-8-21 16:16:26 | 显示全部楼层
谢谢分享
发表于 2020-9-3 04:05:18 | 显示全部楼层
great
发表于 2020-9-3 06:52:37 | 显示全部楼层
感谢
GMT+8, 2025-12-25 22:34 , Processed in 0.022513 second(s), 3 queries , Gzip On, Redis On.
