楼主 |
发表于 2020-5-20 20:42:32
显示全部楼层
Hi , thank you for your advise. for debug my circuit I change (DAC, Comparator, Sample Switch and DAC Driver with Ideal Elements) and this my result:
SNDR=59.92 dB , ENOB=9.66 , SFDR=63.8dB. after many search in the internet, I found that amplitude of input signal impress the SFDR. by changing the input amplitude the SFDR will change but I don't know how shal I set the input amplitude for best result
