查看: 2372|回复: 2
询问有关滤波器设计
发表于 2007-11-29 20:49:38 | 显示全部楼层 |阅读模式
对于滤波器而言,如果输入信号幅度很小,比如电源电压3v,而输入信号Vpp只有1mV~100mV左右,这样是不是因为滤波器的输入信号幅度太小而影响滤波器的性能呢|?
有关于这方面论述的资料吗?
发表于 2007-11-30 22:07:47 | 显示全部楼层
It may be dependent on the architecture of your filter. But the input and output impedance is also a factor.
 楼主| 发表于 2007-12-3 09:23:42 | 显示全部楼层
IF the filter is a active butterworth bandpass fiter
what is the effect of the input signal's amplitude?
GMT+8, 2025-12-4 05:54 , Processed in 0.015402 second(s), 7 queries , Gzip On, Redis On.
