查看: 1750|回复: 5
sha256 error please help
发表于 2020-4-24 13:27:22 | 显示全部楼层 |阅读模式
Can't Install O-2018.09-SP2 release of finesim: SHA256 sum mismatch for file /home/synopsys/installer5/snps_installer_temp_root_3576/finesim.taz, expected 135b509cb878100b342ad6c2a349d9f4c707ab19bcc779c06b3eba8d5d619558, but found 9b7419d22d34184b024eb9653899593e9377d49ad5d3607f1a58894b3592e7e3 /home/synopsys/installer5/snps_installer_temp_root_3576/finesim.taz
发表于 2020-4-24 13:33:22 | 显示全部楼层
安装包有问题
 楼主| 发表于 2020-4-24 13:44:26 | 显示全部楼层
i have re downloaded  and checked same problem
发表于 2020-4-24 13:53:29 | 显示全部楼层
where are you download?
 楼主| 发表于 2020-4-24 14:04:10 | 显示全部楼层
发表于 2020-4-24 14:06:29 | 显示全部楼层
应该是文件包的问题。
taz应该是tar.gz的另一种命名形式。试试先对finesim.taz文件用gunzip解压缩,看看是否正常;如果没问题,再用tar -xvf解包。或直tar -xvfz看看能否解开
GMT+8, 2025-12-26 13:22 , Processed in 0.017103 second(s), 4 queries , Gzip On, Redis On.
