查看: 3586|回复: 5
[求助] 关于check tluplus的问题
发表于 2020-4-12 08:12:52 | 显示全部楼层 |阅读模式
最近使用smic 180工艺库,在使用ICC时,set tluplus_max以及tluplus_min,
tluplus max:smiclog018_6lm_cell_max.tluplus
tluplus min: smiclog018_6lm_cell_min.tluplus
tf files      :smic18_6lm.tf
                            图一、 itf  file
                         图二、tf file
自己写了一个map文件,如下:
#conducting layers
metal1 metal1
metal2 metal2
metal3 metal3
metal4 metal4
metal5 metal5
metal6 metal6
poly poly
polyCont polyCont
#via layers
via1 via1
via2 via2
via3 via3
via4 via4
via5 via5
但是 check_tlu_plus_files的时候,总是报一下错误:
Error: Layer "METAL1" (metal1) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL2" (metal2) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL3" (metal3) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL4" (metal4) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL5" (metal5) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL6" (metal6) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
----------------- Check Ends ------------------
0
 楼主| 发表于 2020-4-12 08:14:21 | 显示全部楼层
求助各位大佬,能否告知是什么原因?对照ICC user guide,感觉没有错误
发表于 2022-9-7 20:01:19 | 显示全部楼层
解决了吗
发表于 2022-12-2 22:37:56 | 显示全部楼层
同样问题,是库没设置好吗
发表于 2023-1-26 23:50:19 | 显示全部楼层
解决了吗
发表于 2024-11-28 20:39:10 | 显示全部楼层
我也是想知道的
GMT+8, 2025-12-23 00:56 , Processed in 0.029933 second(s), 6 queries , Gzip On, Redis On.
