查看: 2516|回复: 0
[求助] ICC中出现的错误
发表于 2020-4-8 12:58:10 | 显示全部楼层 |阅读模式
在ICC的setup阶段执行命令:
icc_shell> list_libs
Warning: No libraries to list. (UID-275)
点击 UID-275,出现:
The error is:
couldn't fork child process: not enough memory
Extended error information is:
    while executing
"open "|cat $tmpfilename | $man2html" r"
    (procedure "snpsDocBrowser::getManPageAsHtml_builtinMan" line 36)
    invoked from within
"getManPageAsHtml_builtinMan $f"
    (procedure "snpsDocBrowser::getManPageAsHtml" line 14)
    invoked from within
"snpsDocBrowser::getManPageAsHtml UID-275"
icc_shell> derive_pg_connection -power_net $p_name -power_pin $p_name -ground_net $g_name -ground_pin $g_name
Error: Pin name VDD specified by power_pin or ground_pin option is invalid. (MWUI-715)
Error: Pin name VSS specified by power_pin or ground_pin option is invalid. (MWUI-715)
Error: derive_pg_connection failed
点击MWUI-715,出现:
Error evaluating dynamic page.
The error is:
    while executing
    invoked from within
    invoked from within
"snpsDocBrowser::getManPageAsHtml MWUI-715"
请问有人知道只是什么原因吗?怎么解决?
GMT+8, 2025-12-15 13:34 , Processed in 0.011117 second(s), 4 queries , Gzip On, Redis On.
