Init: read install configuration file: C:\synopsys\Hspice_F-2011.09\meta.cfg
**info** *pvaI* Module (OTS): 2 unexpanded port, 4 init, 10 behav, 1 contrib, 48/9 expr(s)
**info** *pvaI* Has DIS, 0 afCount
**info** *pvaI* Module (OTS): generated 0 flow node(s) during compilation.
**info** *pvaI* #### Total 341 line-size(s), 48 expr(s), 1 contr(s), 4 init(s), 10 behav(s), 2 port(s)
**error** (c:\users\吴熙\desktop\pcm_code\yf0401\ots.sp:17) Definition of model/subckt "ots" is not found for the element "x1". Please specify a defined model/subckt name.
