查看: 3779|回复: 6
[求助] 跑LVS时,使用CCI.LVS的会报错,XRC.LVS的能通过是什么原因?
发表于 2020-3-23 17:21:32 | 显示全部楼层 |阅读模式
原电路太复杂了,直接拿反相器做例子。
XRC.LVS的出笑脸了
跑CCI.LVS的时候的报错是这样的:
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         inv500
SOURCE CELL NAME:         inv500
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              4         4
Nets:               4         4
Instances:          1         0    *    MN (4 pins)
                     1         0    *    MP (4 pins)
                     1         0    *    D (2 pins)
                     0         1    *    n11ll_ckt (4 pins)
                     0         1    *    p11ll_ckt (4 pins)
Total Inst:         3         2
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              4         4
Nets:               4         4
Instances:          0         1    *    n11ll_ckt (4 pins)
                     1         0    *    _invv (4 pins)
Total Inst:         1         2
       * = Number of objects in layout different from number in source.
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               4          4            0            0
   Nets:                4          4            0            0
   Instances:           0          0            0            1    n11ll_ckt
                        0          0            0            1    p11ll_ckt
                        0          0            1            0    _invv
   Total Inst:          0          0            1            2
o Statistics:
   1 layout instance was filtered and its pins removed from adjoining nets.
o Initial Correspondence Points:
   Ports:        VDDA GNDA X Y
发表于 2020-3-23 18:38:49 来自手机 | 显示全部楼层
类型没有match上
发表于 2020-3-24 08:46:37 | 显示全部楼层
mos type unmatched
 楼主| 发表于 2020-3-24 09:21:28 | 显示全部楼层
s421490542 发表于 2020-3-24 08:46
mos type unmatched
how to match the mos type?
 楼主| 发表于 2020-3-24 09:22:32 | 显示全部楼层
omityoung 发表于 2020-3-23 18:38
类型没有match上
能请问一下怎么match吗?新手之前都是跑的XRC.LVS,没有遇到过类似的问题。eetop也没有搜到相关的问题
发表于 2022-6-16 11:29:42 | 显示全部楼层
请问解决了吗?我也是同样的问题,好像是无法识别到layout的N,PMOS
发表于 2022-6-16 19:01:36 | 显示全部楼层
看下layout 层次是否用对了
GMT+8, 2025-12-21 23:18 , Processed in 0.016403 second(s), 3 queries , Gzip On, Redis On.
