查看: 12491|回复: 11
[求助] Cadence上直流扫描出问题。
发表于 2020-3-13 22:15:19 | 显示全部楼层 |阅读模式
Writing simulator output to file "/root/simulation/DC/spectre/schematic/netlist/paraplot-sim-out".
21 parametric simulations remaining.
Setting Vgs = 1
Begin Incremental Netlisting Mar 13 07:08:10 2020
End netlisting Mar 13 07:08:11 2020
        The netlist is up to date.
        Time taken to compare the design with netlist:   1.0s
INFO (ADE-3069): Errors encountered during simulation. For more information, see the log files
        accessible from the Simulation -> Output Log menu.
Simulation unsuccessful during parametric sweep
Stopping parametric simulation...
INFO (ADE-3072): Simulation is stopped by user. Simulation results may not be complete.
WARNING (OCN-6040): The specified directory does not exist, or the directory does not contain valid PSF results.
        Ensure that the path to the directory is correct and the directory has a logFile and PSF result files.
The simulator output is in the file "/root/simulation/DC/spectre/schematic/netlist/paraplot-sim-out".
Parametric simulation failed for first point.
用台积电180nm的管子直流扫描时出现以上问题,相同的操作130nm就能正常扫描。我怀疑是工艺模型出了问题,有哪位大佬可以解答一下吗?感激不尽。。。。
发表于 2020-10-6 22:41:31 来自手机 | 显示全部楼层
我遇到了类似问题,而且看不到错在哪里?准备放弃了
发表于 2020-10-27 14:27:42 | 显示全部楼层
所以,问题后来解决了吗
 楼主| 发表于 2020-10-28 15:07:46 | 显示全部楼层
lovae 发表于 2020-10-27 14:27
所以,问题后来解决了吗
哎,估计就工艺库有问题。没去深究了,有办法还是获取正规渠道的PDK吧
发表于 2020-10-29 16:36:48 | 显示全部楼层
好的好的
发表于 2021-9-22 09:13:58 | 显示全部楼层
真的是工艺库的问题么?
 楼主| 发表于 2021-9-22 19:49:06 | 显示全部楼层
ZhenWT 发表于 2021-9-22 09:13
真的是工艺库的问题么?
是啊,当时网上随便找的,一对比就会发现缺很多文件
发表于 2022-5-27 13:51:13 | 显示全部楼层
是需要添加工艺库里面的具体文件吗?
正常仿真都可以,就是在config里面仿真就不行了
发表于 2022-8-23 20:48:36 | 显示全部楼层
我也出现了这个问题,但是原因有点弱智了……我没设置Model Library Setup,设置好了就能正常用了
发表于 2023-7-24 20:36:03 | 显示全部楼层
https://www.docin.com/p-1776574904.html
这个教程里面有写一部分相关教程,可以参考看看,我之前失败没有画出理想图像,是因为没有在ADE的output中to be saved->select on design中选中相应nmos的端口。
GMT+8, 2025-12-26 07:37 , Processed in 0.024350 second(s), 4 queries , Gzip On, Redis On.
