查看: 16172|回复: 69
Design of Low-Voltage CMOS Switched-Opamp Switched-Capacitor Systems
发表于 2007-11-28 12:22:07 | 显示全部楼层 |阅读模式
Design of Low-Voltage CMOS Switched-Opamp Switched-Capacitor Systems (The Springer International Series in Engineering and Computer Science) (Hardcover)
by Vincent S.L. Cheung and Howard Cam H. Luong
210 pages
Publisher: Springer; 1 edition (June 30, 2003)
ISBN-10: 1402074662
ISBN-13: 978-1402074660
Table of contents
List of Figures. List of Tables. Preface. Acknowledgement.
1. Introduction.
2. Analysis and Design Considerations of Switched-Opamp Techniques.
3. System Considerations for Switched-Opamp Circuits.
4. Circuit Implementation and Layout Considerations for Switched-Opamp Circuits.
5. Design of a Switched-Capacitor Pseudo-2-Path Filter Using Multi-Phase Switched-Opamp Technique.
6. Design of Low-Power and High-Frequency Switched-Opamp Circuits.
7. Design of Low-Power and High-Level Integrated Switched-Opamp Circuits.
8. Design of Ultra-Low-Power Single-Switched-Opamp-Based Systems.
9. Conclusion.
Appendix A: Procedures of Performing Time Domain Analysis of SC Circuits.
Appendix B: Analysis of Finite-Opamp-Gain Effects on Inverting SC Integrators.
Appendix C: Design Procedures of SC Biquadratic Filter.
Appendix D: Design Procedures of SC Ladder Filter.
References. Index.
Book Description
Demand for low-power low-voltage integrated circuits (ICs) has rapidly grown due to the increasing importance of portable equipment in all market segments including telecommunications, computers, and consumer electronics. The need for low-voltage ICs is further motivated by CMOS technology scaling that requires low supply voltages for device reliability. On the other hand, switched-capacitor (SC) circuits, which have been well known for high accuracy and low distortion, have also become increasingly attractive for low-voltage, low-power, and even high-frequency applications. Switched-opamp (SO) technique has been proposed to enable SC circuits to operate with a single 1-V supply in standard CMOS processes without any clock voltage multiplier or low-threshold devices. However, the existing SO technique requires the opamps to turn off after their integrating phases and thus is not suitable for most of the switched-capacitor systems.
In Design of Low-Voltage CMOS Switched-Opamp Switched-Capacitor Systems, the emphasis is put on the design and development of advanced switched-opamp architectures and techniques for low-voltage low-power switched-capacitor (SC) systems. Specifically, the book presents a novel multi-phase switched-opamp technique together with new system architectures that are critical in improving significantly the performance of switched-capacitor systems at low supply voltages:
*A generic fast-settling double-sampling SC biquadratic filter architecture is proposed to achieve high-speed operation for SC circuits.
*A low-voltage double-sampling (DS) finite-gain-compensation (FGC) technique is employed to realize high-resolution SD modulator using only low-DC-gain opamps to maximize the speed and to reduce power dissipation.
*A family of novel power-efficient SC filters and SD modulators are built based on using only half-delay SC integrators.
*Single-opamp-based SC systems are designed for ultra-low-power applications. In addition, on the circuit level, a fast-switching methodology is proposed for the design of the switchable opamps to achieve switching frequency up to 50 MHz at 1V, which is improved by about ten times compared to the prior arts.
Finally, detailed design considerations, architecture choices, and circuit implementation of five chip prototypes are presented to illustrate potential applications of the proposed multi-phase switched-opamp technique to tackle with and to achieve different stringent design corners such as high-speed, high-integration-level and ultra-low-power consumption at supply voltages of 1V or lower in standard CMOS processes.
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part01.rar
976.56 KB, 下载次数: 222 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-11-28 12:24:32 | 显示全部楼层
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part02.rar
976.56 KB, 下载次数: 206 , 下载积分: 资产 -2 信元, 下载支出 2 信元
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part03.rar
976.56 KB, 下载次数: 198 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-11-28 12:33:50 | 显示全部楼层
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part04.rar
976.56 KB, 下载次数: 191 , 下载积分: 资产 -2 信元, 下载支出 2 信元
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part05.rar
976.56 KB, 下载次数: 178 , 下载积分: 资产 -2 信元, 下载支出 2 信元
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part06.rar
976.56 KB, 下载次数: 192 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-11-28 12:37:23 | 显示全部楼层
网络问题,只能打小点的包。望大家见谅!
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part07.rar
design_of_low-voltage_cmos_switched-opamp_switched-capacitor_systems.part08.rar
952.67 KB, 下载次数: 185 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-11-28 22:28:57 | 显示全部楼层
谢谢楼主的无私奉献
发表于 2007-11-28 23:47:26 | 显示全部楼层
文件太多,分割太细
发表于 2007-11-28 23:48:34 | 显示全部楼层
路过路过路过
发表于 2007-11-28 23:51:14 | 显示全部楼层
分割太细分割太细
发表于 2007-11-29 14:36:36 | 显示全部楼层
附件太小了,没钱啊!
发表于 2007-11-29 14:38:56 | 显示全部楼层
附件太多了!!
GMT+8, 2025-12-28 16:23 , Processed in 0.043354 second(s), 7 queries , Gzip On, Redis On.
