查看: 8096|回复: 19
[原创] DDR3 V.S. DDR4 V.S. DDR5
发表于 2020-3-11 10:33:21 | 显示全部楼层 |阅读模式
[td]
Feature/Option
DDR3
DDR4
DDR4 Advantage
Voltage (core and I/O) 1.5V 1.2V Reduces memory power demand
VREF inputs 2 – DQs and CMD/ADDR 1 – CMD/ADDR VREFDQ now internal
Low voltage standard Yes (DDR3L at 1.35V) No Memory power reductions
Data rate (Mb/s) 800, 1066, 1333, 1600, 1866, 2133 1600, 1866, 2133, 2400, 2666, 3200 Migration to higher‐speed I/O
Densities 512Mb–8Gb 2Gb–16Gb Better enablement for large-capacity memory subsystems
Internal banks 8 16 More banks
Bank groups (BG) 0 4 Faster burst accesses
tCK – DLL enabled 300 MHz to 800 MHz 667 MHz to 1.6 GHz Higher data rates
t CK – DLL disabled 10 MHz to 125 MHz (optional) Undefined to 125 MHz DLL-off now fully supported
Read latency AL + CL AL + CL Expanded values
Write latency AL + CWL AL + CWL Expanded values
DQ driver (ALT) 40Ω 48Ω Optimized for PtP (point-to-point) applications
DQ bus SSTL15 POD12 Mitigate I/O noise and power
RTT values (in Ω) 120, 60, 40, 30, 20 240, 120, 80, 60, 48, 40, 34 Support higher data rates
RTT not allowed READ bursts Disables during READ bursts Ease-of-use
ODT modes Nominal, dynamic Nominal, dynamic, park Additional control mode; supports OTF value change
ODT control ODT signaling required ODT signaling not required Ease of ODT control, allows non-ODT routing on PtP applications
Multipurpose register (MPR) Four registers – 1 defined, 3 RFU Four registers – 3 defined, 1 RFU
 楼主| 发表于 2020-3-11 10:35:00 | 显示全部楼层
[td]
Feature/Option
DDR4
DDR5
DDR5 Advantage
Data rates 1600-3200 MT/s 3200-6400 MT/s Increases performance and bandwidth
VDD/VDDQ/VPP 1.2/1.2/2.5 1.1/1.1/1.8 Lowers power
Internal VREF VREFDQ VREFDQ, VREFCA, VREFCS Improves voltage margins, reduces BOM costs
Device densities   2Gb-16Gb   8Gb-64Gb   Enables larger monolithic devices
Prefetch   8n 16n   Keeps the internal core clock low
DQ receiver equalization CTLE DFE Improves opening of the received DQ data
eyes inside the DRAM
Duty cycle adjustment (DCA) None DQS and DQ Improves signaling on the transmitted DQ/DQS pins
Internal DQS delay
monitoring
None DQS interval oscillator Increases robustness against environmental changes
On-die ECC None 128b+8b SEC, error check and scrub Strengthens on-chip RAS
CRC Write Read/Write   Strengthens system RAS by protecting read data
Bank groups (BG)/banks 4 BG x 4 banks (x4/x8)
2 BG x 4 banks (x16)
8 BG x 2 banks (8Gb x4/x8)
4 BG x 2 banks (8Gb x16)
8 BG x 4 banks (16-64Gb x4/x8)
4 BG x 4 banks (16-64Gb x16)
Improves bandwidth/performance
Command/address interface ODT, CKE, ACT, RAS,
CAS, WE, A<X:0>
CA<13:0>
[size=1.125] Dramatically reduces the CA pin count
ODT DQ, DQS, DM/DBI DQ, DQS, DM, CA bus   Improves signal integrity, reduces  BOM costs
Burst length BL8 (and BL4) BL16, BL32
(and BC8 OTF, BL32 OTF)
Allows 64B cache line fetch with only 1 DIMM subchannel.
MIR (“mirror” pin) None Yes Improves DIMM signaling
Bus inversion Data bus inversion (DBI) Command/address inversion (CAI) Reduces VDDQ noise on modules
CA training, CS training None CA training, CS training Improves timing margin on CA and CS pins
Write leveling training modes Yes Improved Compensates for unmatched DQ-DQS path
Read training patterns Possible with the MPR Dedicated MRs for serial
(userdefined), clock and LFSR
-generated training patterns
Makes read timing margin more robust
Mode registers 7 x 17 bits Up to 256 x 8 bits
(LPDDR type read/write)
Provides room to expand
PRECHARGE commands All bank and per bank All bank, per bank, and same bank PREsb enables precharging-specific bank in each BG
REFRESH commands All bank All bank and same bank REFsb enables refreshing of specific bank in each BG
Loopback mode None Yes Enables testing of the DQ and DQS signaling
回复 支持 2 反对 0
发表于 2020-5-22 15:10:50 | 显示全部楼层
楼主有没有进一步详细的资料?
 楼主| 发表于 2020-5-22 17:02:38 | 显示全部楼层
lwjee 发表于 2020-5-22 15:10
楼主有没有进一步详细的资料?
好久不见 你头像很清纯啊~
这个是不是只能看标准了
发表于 2020-5-25 06:37:55 | 显示全部楼层
固执的寻觅 发表于 2020-5-22 17:02
好久不见 你头像很清纯啊~
这个是不是只能看标准了
谢谢!
发表于 2020-9-25 15:25:48 | 显示全部楼层
发表于 2020-10-7 22:20:58 | 显示全部楼层
不错!
发表于 2020-11-2 14:24:02 | 显示全部楼层
感谢!
发表于 2020-11-4 14:34:19 | 显示全部楼层
有个错误,write leveling不是补偿tDQS2DQ的,write training才是
发表于 2020-11-10 17:40:14 | 显示全部楼层
谢谢楼主分享
GMT+8, 2025-10-13 06:32 , Processed in 0.017716 second(s), 3 queries , Gzip On, Redis On.
