查看: 5457|回复: 9
[求助] 求助:layout高亮,virtuoso便退出
发表于 2020-3-5 10:37:31 | 显示全部楼层 |阅读模式
求助有经验的兄弟,最近每次高亮layout某根线,马上便推出服务器,virtuoso也会关掉。请问如何解决?
之前开电路窗口较多时,关闭某个电路时,也会发生连同virtuoso一起退出的情形。
layout高亮退出时,报错误如附件
发表于 2020-3-5 11:16:49 | 显示全部楼层
正版还是别的。。。。。。我也经常闪退
发表于 2020-3-6 06:14:42 | 显示全部楼层
看log信息,会有说明的,根据说明就找到原因了
发表于 2020-3-6 07:30:49 | 显示全部楼层
61以后的版本
1)checkSysConf 检查系统,是否缺少package
2)oaScan 扫描database,
上面两个可以解决80%的crash
51的非正版的太多,看log吧
 楼主| 发表于 2020-3-6 15:32:17 | 显示全部楼层
aibbt 发表于 2020-3-6 07:30
61以后的版本
你说的我看不懂,能解释一下具体怎么操作么?
startdate:Thu Mar 5 14:54:23 2020
crashdate:Thu Mar 5 14:56:07 2020
appname:virtuoso
version(#)$CDS: virtuoso version 6.1.7-64b 11/09/2015 12:45 (sjfnl165) $
subversion:IC6.1.7-64b.78
mem:2716069888 (total 134773768192)memavail:123655140k (total 135809308k)
signal:SegFault(11)
user:xuq
host:xf-ic (x86_64)
osinux
osversion: 3.10.0-693.11.1.el7.x86_64 #1 SMP Mon Dec 4 23:52:40 UTC 2017 x86_64
xserver:NetSarang Computer, Inc.
xversion:11.0 (vendor release 5028)
display:localhost:10.0
qtversion:4.8.5
cdslog:/tmp/crashReport_030520_145607_IC6.1.7-64b.78_xuq_xf-ic.log.CDS.log
cmd:566:6579.22:8111.265
cmd:568:hiZoomOutAtMouse()
cmd:569:6580.415:8107.605
cmd:571:hiZoomIn()
cmd:572:6579.62:8061.54
cmd:574:addPoint(hiGetCommandPoint())
cmd:575:6607.95:8019.175
cmd:578:leHiMarkNet()
cmd:580:mouseAddPt(t)
cmd:581:6590.322:8033.4
warning:309:Or remove or comment out DEFINE x1320sec_pll_jiaxw
warning:310:in /var/disk2/projects/x1320sec/cds.lib
warning:311:to suppress this warning message.
warning:312:*WARNING* The directory: '/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub' does not exist
warning:313:but was defined in libFile '/var/disk2/projects/x1320sec/xuq/virtuoso/cds.lib' for Lib 'X1320SEC_layout_liub'.
warning:383:*WARNING* (loadContext): context /grid/cic/ICADV_CM2/IC6.1.7/RTM/lnx86/64/buildInProgress/tools/dfII/etc/context/64bit/pCellGen.cxt already loaded
warning:385:*WARNING* (loadContext): context pcellCode already loaded
warning:387:*WARNING* (loadContext): context mom already loaded
warning:389:*WARNING* (loadContext): context tsmc18 already loaded
warning:596:*WARNING* Process was terminated with SIGSEGV signal
signal_by:system
skill:<<< Stack Trace >>>
skill: _insideilparser = t
skill... in leHiMarkNet ...)
skill: tmpFile = nil
skill: fileName = "noName"
skill: allLayersList = ((((& & & nil) (& & & nil) (& & & nil) (& & & nil) (& & & nil) ... ) (("OLY1" "allPurp") ("CONT" "allPurp") ("METAL1" "allPurp") nil)) nil nil)
skill: formName = "le0MarkNetForm"
skill: widgetId = ptrnum@0x18c601a0
skill: form = formStruct@0x179eb098
skill: techFileId = db:0x17c0bb9a
skill: stopLayers = nil
skill: equivLayers = nil
skill: viaLayers = ((("METAL2" "allPurp") ("VIA23" "allPurp") ("METAL3" "allPurp") (t)) (("METAL1" "allPurp") ("VIA12" "allPurp") ("METAL2" "allPurp") (t)))
skill: cellViewId = db:0x17c0a61a
skill: windowId = window:3
skill:leHiMarkNet()
skill:<<< End Stack >>>
stack:libpthread.so.0:__restore_rt+0()
stack:liboaDesign.so:OpenAccess_4:aOccDataTbl::isBound() const+60()
stack:liboaDesign.so:OpenAccess_4:aOccDataTbl::initDynamicData()+9()
stack:liboaBase.so:OpenAccess_4:aDatabase::initDynamicData()+70()
stack:liboaDesign.so:OpenAccess_4::oaDesignData::initDynamicData()+13()
stack:liboaBase.so:OpenAccess_4::oaThreadUseModelMgr<(OpenAccess_4::oaThreadUseModelEnum)1>::initDatabases()+154()
stack:liboaBase.so:OpenAccess_4::oaThreadUseModelMgr<(OpenAccess_4::oaThreadUseModelEnum)1>::preCondition()+9()
stack:liboaBase.so:OpenAccess_4::oaSessionData::setThreadUseModel(OpenAccess_4::oaThreadUseModelEnum)+69()
stack:virtuoso:lceNewUseModel::lceThreadManagerCL::lceThreadManagerCL()+171()
stack:virtuoso:lceNewUseModel::lceBasePhysicalShapeChaserCL::chaseShapesWithThreads()+968()
stack:virtuoso:lceNewUseModel::lceBasePhysicalShapeChaserCL::chaseShapes(unsigned int)+85()
stack:virtuoso:lceNewUseModel::lceClientPhysicalShapeChaserCL<OpenAccess_4::oaTransform>::startFrom(std::deque<lceNewUseModel::lceShapeCL const*, std::allocator<lceNewUseModel::lceShapeCL const*> > const&, std::deque<unsigned int, std::allocator<unsigned int> > const*, OpenAccess_4::oaPoint const*)+617()
stack:virtuoso:lceNewUseModel::lceClientPhysicalShapeChaserCL<OpenAccess_4::oaTransform>::startFrom(OpenAccess_4::oaPoint const&, unsigned int, unsigned int)+503()
stack:virtuoso:leMarkNetEF::startTracingAtPt(OpenAccess_4::oaPoint const&, lceLayerPurposePair const&)+571()
stack:virtuoso:leMarkNetEF::done(char, char, _hiEFunStruct*)+114()
stack:virtuoso:doneCB+232()
stack:virtuoso:hiApplyEnterFunction+356()
stack:virtuoso:leMarkNetEF::addPoint(_hiEFunStruct*)+693()
stack:virtuoso:addPointCB+122()
stack:virtuoso:hiiStackAddPoint+567()
stack:virtuoso:hiiLineAddPointProc+200()
stack:virtuoso:addPoint(_hiWindow*, vodbPoint*)+370()
stack:virtuoso:hifAddPoint+118()
stack:libil_sh.so:iliVcodeEval2C+5397()
stack:libil_sh.so:iliVcodeEval2+71()
stack:libil_sh.so:ilxSkillEval2+220()
stack:libil_sh.so:_ilTopLevelSet+167()
stack:libil_sh.so:ilxTopLevelCmd+227()
stack:virtuoso:hiiPassCmdToIL+220()
stack:virtuoso:hiiProcessEnqueuedCmds() [clone .part.5]+803()
stack:virtuoso:hiiProcessEvent+1889()
stack:virtuoso:cdsHiqtMotif::processEvents(QFlags<QEventLoop:rocessEventsFlag>)+160()
stack:libcdsQtCore.so.4CoreApplication::processEvents(QFlags<QEventLoop:rocessEventsFlag>)+47()
stack:virtuoso:hiiFillCIWInPortCB+1143()
stack:libil_sh.so:iliBGetc+67()
stack:libil_sh.so:input+152()
stack:libil_sh.so:ilyylook+251()
stack:libil_sh.so:ilyylex+46()
stack:libil_sh.so:ilyyparse+1136()
stack:libil_sh.so:ilReadport+774()
stack:libil_sh.so:iliTopLevel+364()
stack:virtuoso:hiiSubEnterEventShell+578()
stack:virtuoso:hiiEnterLineCircleShell(_hiWindow*, _hiEFunStruct*, hiEnterFunctionType)+802()
stack:virtuoso:hiEnterPoint+58()
stack:virtuoso:_leHiMarkNet+275()
stack:virtuoso:lefHiMarkNet+328()
stack:libil_sh.so:iliVcodeEval2C+5535()
stack:virtuoso:hiiProcessEvent+320()
stack:libcdsQtCore.so.4CoreApplication::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)+47()
stack:virtuoso:hiMainLoop+1097()
stack:virtuoso:rde::startHiMainLoop()+3889()
stack:virtuoso:Tcl_Main+377()
stack:virtuoso:TclCommandAdaptor::mainLoop(int, char**, char const*, std::vector<ctuString, std::allocator<ctuString> > const&, void (*)())+528()
stack:virtuoso:finaleEntry(int, char**, char const*, bool, finaleAppHarness*)+3498()
stack:virtuoso:rdeStartMain(int, char**)+43()
stack:virtuoso:main+960()
stack:libc.so.6:__libc_start_main+245()
stack:virtuoso:_start+41()
userenv:ABVIP_ISNT_DIR=/opt/cadence/VIPCAT113/tools/abvip
userenv:AMSHOME=/var/disk2/eda/cadence/INCISIV141
userenv:A__z="*SHLVL
userenv:CADENCE_DIR=/opt/cadence/IC617
userenv:CADENCE_VIP_LIC_ORDER=newrev:soc:portfolio:alacarte
userenv:CADHOME=/opt/cadence
userenv:CALIBRE_HOME=/opt/mentor/calibre/aoi_cal_2015.2_36.27
userenv:CDK_DIR=/opt/PDKs/ncsu-cdk-1.6.0.beta
userenv:CDNS_QTDIR=/opt/cadence/IC617/tools/Qt/64bit
userenv:CDN_VIP_ROOT=/opt/cadence/VIPCAT113
userenv:CDS=/opt/cadence/IC617
userenv:CDSDIR=/opt/cadence/IC617
userenv:CDSHOME=/opt/cadence/IC617
userenv:CDSROOT=/opt/cadence/IC617
userenv:CDS_ARCH=lnx86
userenv:CDS_AUTO_64BIT=ALL
userenv:CDS_ENABLE_VMS=1
userenv:CDS_INST_DIR=/opt/cadence/IC617
userenv:CDS_INST_ROOT=/opt/cadence/IC617
userenv:CDS_LANG=C
userenv:CDS_LIC_FILE=/opt/cadence/license/license.dat
userenv:CDS_LIC_ONLY=1
userenv:CDS_LOAD_ENV=CWD
userenv:CDS_MPS_SESSION=virtuoso112885
userenv:CDS_Netlisting_Mode=Analog
userenv:CDS_ROOT=/opt/cadence/IC617
userenv:CDS_SET_LOCALE=C
userenv:COLORTERM=xfce4-terminal
userenv:CTU_CDSENV_SETTINGS=1
userenv:CTU_COMMON_SETTINGS_VIRTUOSO=1
userenvBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-Vt4DGFmFQj,guid=d4ae8bcab4183010f1a203f75e60a20d
userenvD_NO_TMPDIR_WARN=true
userenvENALI=/opt/cadence/VIPCAT113/tools/denali_64bit
userenv:DISPLAY=localhost:10.0
userenv:FINESIM_64=1
userenv:FINESIM_HOME=/opt/synopsys/finesim
userenv:FINEWAVE_64=1
userenv:HOME=/home/xuq
userenv:K2_HOME=/opt/cadence/PVS151/tools/K2
userenv:K2_MASKCOMPOSE_HOME=/opt/cadence/PVS151/tools/K2/MaskCompose
userenv:K2_MC_DATA=/home/xuq/Projects
userenv:K2_VIEWER_HOME=/opt/cadence/PVS151/tools/K2/Viewer
userenvANG=C
userenvC_ALL=C
userenv:LD_LIBRARY_PATH=/opt/cadence/IC617/share/oa/lib/linux_rhel50_gcc48x_64/opt:/opt/cadence/IC617/tools/Qt/64bit/lib:/opt/cadence/IC617/tools/dfII/lib/64bit:/opt/cadence/IC617/tools/sev/lib/64bit:/opt/cadence/IC617/tools/lib/64bit:/opt/cadence/IC617/tools/lib:/var/disk2/eda/cadence/INCISIV141/tools.lnx86/lib/64bit
userenv:LM_LICENSE_FILE=/opt/synopsys/hspice/synopsys.dat
userenv:LOGNAME=xuq
userenv:MAIL=/var/mail/xuq
userenv:MGC_CALIBRE_LAYOUT_SERVER=xf-ic:9189
userenv:MGC_CALIBRE_LAYOUT_SERVER_NAME=Cadence:Virtuoso
userenv:MGC_CALIBRE_SAVE_ALL_RUNSET_VALUES=1
userenv:MGC_CALIBRE_SCHEMATIC_SERVER=xf-ic:9199
userenv:MGC_HOME=/opt/mentor/calibre/aoi_cal_2015.2_36.27
userenv:MGC_LIB_PATH=/opt/mentor/calibre/aoi_cal_2015.2_36.27/lib
userenv:MGC_PDF_READER=evince
userenv:MGC_RVE_HILIGHT_SHORT_TEXT_CMDS=1
userenv:MGLS_LICENSE_FILE=/opt/mentor/calibre/aoi_cal_2015.2_36.27/shared/license/license.dat
userenv:MMSIMHOME=/opt/cadence/MMSIM151
userenv:MOZILLA_HOME=/usr/bin/firefox
userenv:OA_BIT=64
userenv:OA_UNSUPPORTED_PLAT=linux_rhel50_gcc48x
userenv:OLDPWD=/var/disk2/projects/x1320sec/xuq
userenv:PATH=/opt/cadence/IC617/bin:/opt/cadence/IC617/tools/bin/64bit:/opt/cadence/IC617/tools/bin:/opt/cadence/IC617/share/oa/bin:/opt/synopsys/xa/bin:/opt/synopsys/cewv/bin:/opt/synopsys/scl11.1/amd64/bin:/opt/synopsys/hspice/hspice/bin:/opt/synopsys/xa/bin:/opt/synopsys/cewv/bin:/opt/synopsys/scl11.1/amd64/bin:/opt/synopsys/hspice/hspice/bin:/usr/local/bin:/usr/bin:/opt/cadence/IC617/tools/dfII/bin:/opt/cadence/IC617/tools/plot/bin:/opt/cadence/MMSIM151/bin:/opt/cadence/MMSIM151/tools/relxpert/bin:/var/disk2/eda/cadence/INCISIV141/bin:/var/disk2/eda/cadence/INCISIV141/tools/bin:/var/disk2/eda/cadence/INCISIV141/tools/dfII/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/tools/denali_64bit/bin:/opt/cadence/MVS152/tools/bin:/opt/mentor/calibre/aoi_cal_2015.2_36.27/bin:/opt/synopsys/finesim/bin:/opt/cadence/IC617/tools/dfII/bin:/opt/cadence/IC617/tools/plot/bin:/opt/cadence/MMSIM151/bin:/opt/cadence/MMSIM151/tools/relxpert/bin:/var/disk2/eda/cadence/INCISIV141/bin:/var/disk2/eda/cadence/INCISIV141/tools/bin:/var/disk2/eda/cadence/INCISIV141/tools/dfII/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/tools/denali_64bit/bin:/opt/cadence/MVS152/tools/bin:/opt/mentor/calibre/aoi_cal_2015.2_36.27/bin:/opt/synopsys/finesim/bin
userenv:POWERVIEW_64=1
userenv:PS1= [\u@\h $PWD]\$
userenv:PWD=/var/disk2/projects/x1320sec/xuq/virtuoso
userenvRC_HOME=/opt/cadence/EXT151
userenv:QRC_MOS_LW_PRECISION=Y
userenv:SELINUX_LEVEL_REQUESTED=
userenv:SELINUX_ROLE_REQUESTED=
userenv:SELINUX_USE_CURRENT_RANGE=
userenv:SHELL=/bin/bash
userenv:SHLVL=5
userenv:SNPSLMD_LICENSE_FILE=27000@xf-ic
userenv:SPECMAN_PATH=/opt/synopsys/xa/bin:/opt/synopsys/cewv/bin:/opt/synopsys/scl11.1/amd64/bin:/opt/synopsys/hspice/hspice/bin:/usr/local/bin:/usr/bin:/opt/cadence/IC617/tools/dfII/bin:/opt/cadence/IC617/tools/plot/bin:/opt/cadence/MMSIM151/bin:/opt/cadence/MMSIM151/tools/relxpert/bin:/var/disk2/eda/cadence/INCISIV141/bin:/var/disk2/eda/cadence/INCISIV141/tools/bin:/var/disk2/eda/cadence/INCISIV141/tools/dfII/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/tools/denali_64bit/bin:/opt/cadence/MVS152/tools/bin:/opt/mentor/calibre/aoi_cal_2015.2_36.27/bin:/opt/synopsys/finesim/bin:/opt/cadence/IC617/tools/dfII/bin:/opt/cadence/IC617/tools/plot/bin:/opt/cadence/MMSIM151/bin:/opt/cadence/MMSIM151/tools/relxpert/bin:/var/disk2/eda/cadence/INCISIV141/bin:/var/disk2/eda/cadence/INCISIV141/tools/bin:/var/disk2/eda/cadence/INCISIV141/tools/dfII/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/utils:/opt/cadence/VIPCAT113/packages:/opt/cadence/VIPCAT113/vips/enet/vr_enet
userenv:SSH_AGENT_PID=110457
userenv:SSH_AUTH_SOCK=/tmp/ssh-JLdaTX1pgzLE/agent.110456
userenv:SSH_CLIENT=192.168.1.3 51034 22
userenv:SSH_CONNECTION=192.168.1.3 51034 192.168.1.16 22
userenv:TCL_LIBRARY=/opt/cadence/IC617/tools/dfII/etc/tcl8.4
userenv:TERM=xterm
userenv:TSMC_ASU_DFM_PATH=/opt/PDKs/tsmc/CRNxxG/Assura/lvs_rcx/DFM
userenv:TSMC_CAL_DFM_PATH=/opt/PDKs/tsmc/CRNxxG/Calibre/lvs/DFM
userenv:TSMC_PDK_NAME=tsmc18
userenv:TSMC_PDK_source_added_place=cdl ::  /var/disk2/process/tsmc1833/pdk/tsmc1833_3dmim_1p6m/tsmc18/../Assura/lvs_rcx/source.added
userenv:USER=xuq
userenv:VCA_ENABLE_CSM=15
userenv:W3264_ENV=/home/xuq/.kshrc
userenv:W3264_NO_HOST_CHECK=1
userenv:WINDOWID=44040195
userenv:XDG_RUNTIME_DIR=/run/user/1012
userenv:XDG_SESSION_ID=50
userenv:XKEYSYMDB=/opt/cadence/IC617/tools/plot/etc/XKeysymDB
userenv:XTAPPPEEKEVENT_SKIPTIMER=1
userenv:_=*111031*/opt/cadence/IC617/tools/dfII/bin/64bit/virtuoso
userenv:__DFII_INTEG_NC_PATH__=/var/disk2/eda/cadence/INCISIV141/tools/bin/64bit
userenv:_dfII_bin_bit=/64bit
userenv:df2BaseVhdlin=/var/disk2/eda/cadence/INCISIV141
cdsinit:;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
cdsinit:
cdsinit:;
cdsinit:; check CALIBRE_HOME
cdsinit:;
cdsinit:cal_home=getShellEnvVar("CALIBRE_HOME")
cdsinit:if( cal_home==nil then
cdsinit:    cal_home=getShellEnvVar("MGC_HOME")
cdsinit:    if( cal_home!=nil then
cdsinit:        printf("// CALIBRE_HOME environment variable not set; setting it to value of MGC_HOME\n");
cdsinit:    )
cdsinit
cdsinit:
cdsinit:if( cal_home!=nil && isDir(cal_home) && isReadable(cal_home) then
cdsinit:
cdsinit:    ; Load calibre.skl or calibre.4.3.skl, not both!
cdsinit:
cdsinit:    ; Load calibre.skl for Cadence versions 4.4 and greater
cdsinit:    load(strcat(cal_home "/lib/calibre.skl"))
cdsinit:
cdsinit:;;;;Load calibre.4.3.skl for Cadence version 4.3
cdsinit:;;; load(strcat(cal_home "/lib/calibre.4.3.skl"))
cdsinit:
cdsinit:else
cdsinit:
cdsinit:    ; CALIBRE_HOME is not set correctly. Report the problem.
cdsinit:
cdsinit:    printf("//  Calibre Error: Environment variable ")
cdsinit:
cdsinit:    if( cal_home==nil || cal_home=="" then
cdsinit:        printf("CALIBRE_HOME is not set.");
cdsinit:    else
cdsinit:        if( !isDir(cal_home) then
cdsinit:            printf("CALIBRE_HOME does not point to a directory.");
cdsinit:        else
cdsinit:            if( !isReadable(cal_home) then
cdsinit:                printf("CALIBRE_HOME points to an unreadable directory.");
cdsinit:            )
cdsinit:        )
cdsinit:    )
cdsinit:    printf(" Calibre Skill Interface not loaded.\n")
cdsinit:
cdsinit:    ; Display a dialog box message about load failure.
cdsinit:
cdsinit:    hiDisplayAppDBox(
cdsinit:        ?name           'MGCHOMEErrorDlg
cdsinit:        ?dboxBanner     "Calibre Error"
cdsinit:        ?dboxText       "Calibre Skill Interface not loaded."
cdsinit:        ?dialogType     hicErrorDialog
cdsinit:        ?dialogStyle    'modal
cdsinit:       ?buttonLayout   'Close
cdsinit:    )
cdsinit
cdsinit:   hiSetFont("ciw" ?size 13)
cdsinit:   hiSetFont("label" ?name "Open Sans" ?size 13)
cdsinit:   hiSetFont("text" ?name "Roboto Mono" ?size 13)
cdsinit:
cdsinit:
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/etc/cdsDefTechLib':
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/etc/cdsDefTechLib/cdsinfo.tag
cdslibinfo:    defines 'DMTYPE none'.
cdslibinfo:Info (cdsinfo): Library checking is off, CDSLIBRARY entries will not be used.
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/etc/cdsDefTechLib/cdsinfo.tag
cdslibinfo:has a CDSLIBRARY entry defined.
cdslibinfo:    defines 'NAMESPACE libraryUnix'.
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths':
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/samples/artist/rfLib':
cdslibinfo:Info (cdsinfo): could not locate an entry for 'DMTYPE' in any cdsinfo.tag file.
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/samples/artist/rfLib/cdsinfo.tag
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/samples/artist/rfLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/samples/artist/rfExamples':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/samples/artist/rfExamples/cdsinfo.tag
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/samples/artist/rfExamples/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/samples/artist/ahdlLib':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/samples/artist/ahdlLib/cdsinfo.tag
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/samples/artist/ahdlLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/artist/functional':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/artist/functional/cdsinfo.tag
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/artist/functional/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/basic':
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/basic/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/basic/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/artist/analogLib':
cdslibinfo:/opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/artist/analogLib/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC617/tools.lnx86/dfII/etc/cdslib/artist/analogLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/process/tsmc1833/pdk/tsmc1833_3dmim_1p6m/tsmc18':
cdslibinfo:/var/disk2/process/tsmc1833/pdk/tsmc1833_3dmim_1p6m/tsmc18/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /var/disk2/process/tsmc1833/pdk/tsmc1833_3dmim_1p6m/tsmc18/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tsmc18_misc':
cdslibinfo:No CDSLIBRARY entry was found in any location relative to
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tsmc18_misc.
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/pdk_1850/pdk/tsmc1850':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/pdk_1850/pdk/tsmc1850/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/pdk_1850/pdk/tsmc1850/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/dprx_pll_pic_tsmc1833':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/dprx_pll_pic_tsmc1833/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/dprx_pll_pic_tsmc1833/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1321c_1850/x1321c_jiaxw':
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1321c_1850/x1321c_jiaxw.
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1321c_1850/x1321c_IO_jiaxw':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1321c_1850/x1321c_IO_jiaxw/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1321c_1850/x1321c_IO_jiaxw/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1321c_1850/tsmc1850_io':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1321c_1850/tsmc1850_io/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1321c_1850/tsmc1850_io/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/x1321c_jiaxw_modify1833_liub':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/x1321c_jiaxw_modify1833_liub/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/x1321c_jiaxw_modify1833_liub/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_bak20190606':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_bak20190606/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_bak20190606/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/process/smic1850/pdk/smic18mm_1850_1tm':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/process/smic1850/pdk/smic18mm_1850_1tm/cdsinfo.tag
cdslibinfo:/var/disk2/process/smic1850/pdk/smic18mm_1850_1tm/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x5129/liub/X1320SEC_layout_liub_test':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x5129/liub/X1320SEC_layout_liub_test/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x5129/liub/X1320SEC_layout_liub_test/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1320sec_jiaxw':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1320sec_jiaxw/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1320sec_jiaxw/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1320sec_roic_jiaxw':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1320sec_roic_jiaxw/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1320sec_roic_jiaxw/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1321c/liub/x1321c_layout_liub':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1321c/liub/x1321c_layout_liub/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1321c/liub/x1321c_layout_liub/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1321c/liub/X1321C_TOP_tapeout':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1321c/liub/X1321C_TOP_tapeout/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1321c/liub/X1321C_TOP_tapeout/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1640sec/X1640SEC':
cdslibinfo:/var/disk2/projects/x1640sec/X1640SEC.
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1640sec/X1640SEC_DIG':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1640sec/X1640SEC_DIG/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1640sec/X1640SEC_DIG/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1640sec/X1640SEC_t':
cdslibinfo:/var/disk2/projects/x1640sec/X1640SEC_t.
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x5129/liub/X1320EC_A2':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x5129/liub/X1320EC_A2/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x5129/liub/X1320EC_A2/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_temp1':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_temp1/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_temp1/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x5129/wangx/x1320sec_layout_wangxu':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x5129/wangx/x1320sec_layout_wangxu/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x5129/wangx/x1320sec_layout_wangxu/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/x1320sec_layout_liub':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/x1320sec_layout_liub/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/x1320sec_layout_liub/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_bak20190625am':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_bak20190625am/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/X1320SEC_layout_liub_bak20190625am/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x5129/liub/schem_flir_liub':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x5129/liub/schem_flir_liub/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x5129/liub/schem_flir_liub/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/process/smic11/pdk/smic11mmrf_1233':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/process/smic11/pdk/smic11mmrf_1233/cdsinfo.tag
cdslibinfo:/var/disk2/process/smic11/pdk/smic11mmrf_1233/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/X1640_ANA_top':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/X1640_ANA_top/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/X1640_ANA_top/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/TEST_lb':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/TEST_lb/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/TEST_lb/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/liub/ANA_TOP_bonding':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/liub/ANA_TOP_bonding/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/liub/ANA_TOP_bonding/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/test_xq':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/test_xq/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/test_xq/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1320sec_jiaxw_test':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1320sec_jiaxw_test/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1320sec_jiaxw_test/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tsmc18_test':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/tsmc18_test/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tsmc18_test/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tsmc18_test1':
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tsmc18_test1.
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/x1320sec_layout_xuq':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/x1320sec_layout_xuq/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/x1320sec_layout_xuq/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1320sec_pll_jiaxw':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1320sec_pll_jiaxw/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1320sec_pll_jiaxw/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tsmc18_test3':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/tsmc18_test3/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tsmc18_test3/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tsmc18_test6':
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tsmc18_test6.
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tsmc18_test5':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/tsmc18_test5/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tsmc18_test5/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/sch_test':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/sch_test/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/sch_test/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tpb018v_180a_cup_6lm':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/tpb018v_180a_cup_6lm/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tpb018v_180a_cup_6lm/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tpb018v_180a_wb_6lm':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/tpb018v_180a_wb_6lm/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tpb018v_180a_wb_6lm/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/tpz018nv_280c_b_6lm':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/tpz018nv_280c_b_6lm/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/tpz018nv_280c_b_6lm/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/IO_sch':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/IO_sch/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/IO_sch/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1320sec_roic_ram_jiaxw':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1320sec_roic_ram_jiaxw/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1320sec_roic_ram_jiaxw/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/test_ongrid':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/test_ongrid/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/test_ongrid/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/jiaxw/x1320sec_IO_jiaxw':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/jiaxw/x1320sec_IO_jiaxw/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/jiaxw/x1320sec_IO_jiaxw/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/process/smic1833/pdk/smic18mmrf':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/process/smic1833/pdk/smic18mmrf/cdsinfo.tag
cdslibinfo:/var/disk2/process/smic1833/pdk/smic18mmrf/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/SRAM_array':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/SRAM_array/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/SRAM_array/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/var/disk2/projects/x1320sec/xuq/virtuoso/x1320sec_layout_xuq_ram':
cdslibinfo:The cdsinfo.tag file at: /var/disk2/projects/x1320sec/xuq/virtuoso/x1320sec_layout_xuq_ram/cdsinfo.tag
cdslibinfo:/var/disk2/projects/x1320sec/xuq/virtuoso/x1320sec_layout_xuq_ram/cdsinfo.tag
xdpyinfo:name of display:    localhost:10.0
xdpyinfo:version number:    11.0
xdpyinfo:vendor string:    NetSarang Computer, Inc.
xdpyinfo:vendor release number:    5028
xdpyinfo:maximum request size:  16777212 bytes
xdpyinfo:motion buffer size:  256
xdpyinfo:bitmap unit, bit order, padding:    32, LSBFirst, 32
xdpyinfo:image byte order:    LSBFirst
xdpyinfo:number of supported pixmap formats:    7
xdpyinfo:supported pixmap formats:
xdpyinfo:    depth 1, bits_per_pixel 1, scanline_pad 32
xdpyinfo:    depth 4, bits_per_pixel 4, scanline_pad 32
xdpyinfo:    depth 8, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 15, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 16, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 24, bits_per_pixel 32, scanline_pad 32
xdpyinfo:    depth 32, bits_per_pixel 32, scanline_pad 32
xdpyinfo:keycode range:    minimum 8, maximum 255
xdpyinfo:focus:  window 0x2800c25, revert to PointerRoot
xdpyinfo:number of extensions:    23
xdpyinfo:    BIG-REQUESTS
xdpyinfo:    DAMAGE
xdpyinfo:    DEC-XTRAP
xdpyinfo:    DOUBLE-BUFFER
xdpyinfo:    DPMS
xdpyinfo:    Extended-Visual-Information
xdpyinfo:    GLX
xdpyinfo:    MIT-SUNDRY-NONSTANDARD
xdpyinfo:    RANDR
xdpyinfo:    RECORD
xdpyinfo:    RENDER
xdpyinfo:    SECURITY
xdpyinfo:    SGI-GLX
xdpyinfo:    SHAPE
xdpyinfo:    SYNC
xdpyinfo:    TOG-CUP
xdpyinfo:    X-Resource
xdpyinfo:    XC-APPGROUP
xdpyinfo:    XC-MISC
xdpyinfo:    XFIXES
xdpyinfo:    XFree86-Bigfont
xdpyinfo:    XInputExtension
xdpyinfo:    XTEST
xdpyinfo:default screen number:    0
xdpyinfo:number of screens:    1
xdpyinfo:screen #0:
xdpyinfo:  dimensions:    3840x1057 pixels (1016x280 millimeters)
xdpyinfo:  resolution:    96x96 dots per inch
xdpyinfo:  depths (17):    1, 4, 8, 8, 8, 8, 15, 16, 24, 24, 24, 24, 24, 24, 24, 24, 32
xdpyinfo:  root window id:    0x58
xdpyinfo:  depth of root window:    24 planes
xdpyinfo:  number of colormaps:    minimum 16, maximum 128
xdpyinfo:  default colormap:    0x20
xdpyinfo:  default number of colormap cells:    256
xdpyinfo:  preallocated pixels:    black 0, white 16777215
xdpyinfo:  options:    backing-store NO, save-unders NO
xdpyinfo:  largest cursor:    32x32
xdpyinfo:  current input event mask:    0xfac03f
xdpyinfo:    KeyPressMask             KeyReleaseMask           ButtonPressMask
xdpyinfo:    ButtonReleaseMask        EnterWindowMask          LeaveWindowMask
xdpyinfo:    KeymapStateMask          ExposureMask             StructureNotifyMask
xdpyinfo:    SubstructureNotifyMask   SubstructureRedirectMask FocusChangeMask
xdpyinfo:    PropertyChangeMask       ColormapChangeMask
xdpyinfo:  number of visuals:    16
xdpyinfo:  default visual id:  0x29
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x21
xdpyinfo:    class:    PseudoColor
xdpyinfo:    depth:    8 planes
xdpyinfo:    available colormap entries:    256
xdpyinfo:    red, green, blue masks:    0x0, 0x0, 0x0
xdpyinfo:    significant bits in color specification:    8 bits
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x22
xdpyinfo:    class:    DirectColor
xdpyinfo:    available colormap entries:    8 per subfield
xdpyinfo:    red, green, blue masks:    0x7, 0x38, 0xc0
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x23
xdpyinfo:    class:    GrayScale
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x24
xdpyinfo:    class:    StaticColor
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x25
xdpyinfo:    class:    StaticGray
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x26
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x27
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x28
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x29
xdpyinfo:    class:    TrueColor
xdpyinfo:    depth:    24 planes
xdpyinfo:    available colormap entries:    256 per subfield
xdpyinfo:    red, green, blue masks:    0xff0000, 0xff00, 0xff
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x2f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x30
sysconf:=====================================================================
sysconf:[Copyright 2002-2015] Cadence Design Systems, Inc. All rights reserved.
sysconf:This  program and online  documentation  may not be copied, modified,
sysconf:re-published, uploaded,  executed, or  distributed in any way, in any
sysconf:medium, whether in whole or in part, without prior written permission
sysconf:from Cadence Design Systems, Inc.
sysconf:============== checkSysConf:  Version 3.20 ====================
sysconf:Configuration checks failed on this workstation (xf-ic), status is: FAIL
sysconf:This vendor centos is not supported
sysconf:Exiting checkSysConf ... Good-bye
sysconf:Output is saved as /tmp/checkSysConf.xf-ic-2020.03.05.14:56.116587.log
 楼主| 发表于 2020-3-6 15:34:50 | 显示全部楼层
61以后的版本
你的所言不是很明白,能解释一下么
把所报错误发上来,欢迎高手帮忙看一下!
 楼主| 发表于 2020-3-6 15:35:53 | 显示全部楼层
用的盗版IC617,把log文本发过来,欢迎高手帮忙看一下:
appname:virtuoso
signal:SegFault(11)
user:xuq
host:xf-ic (x86_64)
osinux
qtversion:4.8.5
cmd:571:hiZoomIn()
signal_by:system
skill:leHiMarkNet()
userenv:CDS_LANG=C
userenvANG=C
userenvC_ALL=C
userenv:LOGNAME=xuq
userenv:OA_BIT=64
userenv:SHLVL=5
userenv:TERM=xterm
userenv:USER=xuq
cdsinit:
cdsinit:;
cdsinit:;
cdsinit:    )
cdsinit
cdsinit:
cdsinit:
cdsinit:
cdsinit:
cdsinit:
cdsinit:else
cdsinit:
cdsinit:
cdsinit:
cdsinit:    else
cdsinit:        else
cdsinit:            )
cdsinit:        )
cdsinit:    )
cdsinit:
cdsinit:
cdsinit:    )
cdsinit
cdsinit:
cdsinit:
xdpyinfo:    DAMAGE
xdpyinfo:    DEC-XTRAP
xdpyinfo:    DPMS
xdpyinfo:    GLX
xdpyinfo:    RANDR
xdpyinfo:    RECORD
xdpyinfo:    RENDER
xdpyinfo:    SECURITY
xdpyinfo:    SGI-GLX
xdpyinfo:    SHAPE
xdpyinfo:    SYNC
xdpyinfo:    TOG-CUP
xdpyinfo:    XC-MISC
xdpyinfo:    XFIXES
xdpyinfo:    XTEST
xdpyinfo:screen #0:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
xdpyinfo:  visual:
发表于 2020-3-6 17:31:48 | 显示全部楼层
这个报告无法分析的,你可以view report,看看里面的errors,
或者在terminal上run checkSysConf和oaScan,你可以使用上面两个command加-help,得到相应的帮助
发表于 2021-2-1 16:31:09 | 显示全部楼层
楼主解决了吗/?
发表于 2021-8-20 17:40:13 | 显示全部楼层
楼主解决了吗?
GMT+8, 2025-12-28 07:37 , Processed in 0.057168 second(s), 5 queries , Gzip On, Redis On.
