大家好!
我在centOS6.7 安装成功了 Openlava4.0, 用行命令方式可以bsub 任务。 队列也是工作的。
但是怎么让ADE里面跑Spectre时也自动丢任务上队列呢? 也就是Virtuoso与openlava的接口怎么设置呢?
目前我的状态是, 在ADE提交distribute任务后,CIW报错:
*Error* lbpsGetComponentHandle: Failure initializing LSF using lsb_init(): Failed in an LSF library call: Unable to open file ego.conf
Verify that your LSF distribution (for example, bsub) works
correctly on this host. If it does, then this error might have
occurred because the Cadence executable has different permissions
than the LSF executables, or uses an LSF client library version
which is incompatible with your LSF distribution.
The Cadence /tools/IC617.721/tools/bin/64bit/cdsfrb_lsf7.0
executable uses the LSF 7.02 client library.
Please consult your LSF administrator for help in resolving these issues.
lsb_init() 和ego.conf 在哪里呢?
拜托有经验的同学指导!多谢!必谢!
