查看: 3237|回复: 6
[求助] scl 11.9 for HSPICE
发表于 2020-2-21 20:18:31 | 显示全部楼层 |阅读模式
Hi guys, I need to install SCL11.9 on ubuntu 16.04 OS, but according to downloaded file, there exist 3 file such as "scl_v11.9_amd64.spf", "scl_v11.9_common.spf", and "scl_v11.9_linux.spf". How to install them on ubutu while their suffix is "spf". Any help appreciated.
发表于 2020-2-23 09:59:39 | 显示全部楼层
need new version  synopsys installer
发表于 2020-2-23 10:01:07 | 显示全部楼层
 楼主| 发表于 2020-2-28 00:29:52 | 显示全部楼层
thanks. it works according to ut suggestion. but after completing installation, I have faced with "invalid memory reference " error. Can I solve it?
发表于 2020-3-7 12:05:28 | 显示全部楼层
unix_amr 发表于 2020-2-28 00:29
thanks. it works according to ut suggestion. but after completing installation, I have faced with "i ...
pls  check your license
 楼主| 发表于 2020-3-8 13:11:36 | 显示全部楼层
ok. thnks, checking and renewing the license is the cessation of this problem. solved.
 楼主| 发表于 2020-3-8 14:02:44 | 显示全部楼层
GMT+8, 2025-12-25 09:17 , Processed in 0.016823 second(s), 3 queries , Gzip On, Redis On.
