查看: 2754|回复: 1
[原创] ADS WORKSPACE REQUEST
发表于 2020-1-10 03:41:28 来自手机 | 显示全部楼层 |阅读模式
Could anyone please share the workspace at the following link?
Simulating RF Chains with Keysight ADSRF designers want to know the S-parameters of different stages in their RF chains as well as things like mismatch loss between stages. You can obtain this information from a single S-parameter simulation.  The new (to ADS 2020) WSProbe (Winslow Stability Probe) makes this sort of analysis much easier.  This example workspace shows two ways of analyzing RF chains, one using the WSProbe, and the other using the older SP_Probe.​  The WSProbe is more flexible and also provides information for stability analysis.  Supported users may (after first logging into the Keysight EEsof Knowledge Center) download the workspace here:https://lnkd.in/dFJ_AH9
发表于 2024-4-14 23:41:09 | 显示全部楼层
Hi brother
There is a tutorial on youtube that is very straightforward to design a power amplifier and doesn't have the complexity of conventional methods.
But unfortunately, it can only be accessed with a license.
The tutorial link is as follows:
https://www.youtube.com/watch?v=-GLPH9BYvSo
If you have access to this file, please share it with me. You have done me a great favor by doing this
GMT+8, 2025-12-14 16:00 , Processed in 0.013250 second(s), 4 queries , Gzip On, Redis On.
