查看: 2202|回复: 2
[求助] DC biasing 应该放在 IO 电路附近还是 Core 电路旁?
发表于 2020-1-4 13:09:57 | 显示全部楼层 |阅读模式
发表于 2020-1-6 08:53:57 | 显示全部楼层
core is which type? core size ? and DC bias function ?
 楼主| 发表于 2020-1-6 12:32:01 | 显示全部楼层
So, generally speaking, a DC biasing circuit is simply a current mirror to bias a tail transistor, just wondering if it should be placed beside this transistor or somewhere by the IO pad.
A straightforward thinking is the former for matching reason, however, there are enough layout examples to place the biasing circuit near the IO PAD.
GMT+8, 2025-12-19 22:04 , Processed in 0.014238 second(s), 3 queries , Gzip On, Redis On.
