查看: 3140|回复: 1
[求助] hspice lic
发表于 2019-10-31 23:55:40 | 显示全部楼层 |阅读模式
请问一个hspice安装问题,系统centos6.6,安装hspice2010和2015,用了不同版本的SCL,两个不同版本的lic,一直都有问题,请问这个错误应该怎么解 决呢
23:46:51 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 i86_lsb) started on centos6 (linux) (10/31/2019)
23:46:51 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
23:46:51 (lmgrd) US Patents 5,390,297 and 5,671,412.
23:46:51 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
23:46:51 (lmgrd) License file(s): /opt/eda/synopsys/license/synopsys.dat
23:46:51 (lmgrd) lmgrd tcp-port 50957
23:46:51 (lmgrd) Starting vendor daemons ...
23:46:51 (lmgrd) Started snpslmd (internet tcp_port 59693 pid 4066)
23:46:51 (snpslmd) FlexNet Licensing version v11.12.1.2 build 152538 x64_lsb
23:46:51 (snpslmd) lmgrd version 11.10, snpslmd version 11.12
23:46:51 (snpslmd) Cannot create lock file. Old lockfile exists. errno=13 (/var/tmp/locksnpslmd): Permission denied
23:46:51 (snpslmd) EXITING DUE TO SIGNAL 41 Exit reason 9
23:46:51 (lmgrd) snpslmd exited with status 41 (Exited because another server was running)
23:46:51 (lmgrd) MULTIPLE "snpslmd" license server systems running.
23:46:51 (lmgrd) Please kill, and run lmreread
23:46:51 (lmgrd)
23:46:51 (lmgrd) This error probably results from either:
23:46:51 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
23:46:51 (lmgrd)   2. A prior license server manager (lmgrd) was killed with "kill -9"
23:46:51 (lmgrd)       (which would leave the vendor daemon running).
23:46:51 (lmgrd) To correct this, do a "ps -ax | grep snpslmd"
23:46:51 (lmgrd)   (or equivalent "ps" command)
23:46:51 (lmgrd) and kill the "snpslmd" proc
发表于 2021-8-5 16:03:46 | 显示全部楼层
因为snplslmd已经启动了,要先lmdown,才能lmgrd
GMT+8, 2025-12-30 08:44 , Processed in 0.012638 second(s), 3 queries , Gzip On, Redis On.
