查看: 2674|回复: 1
[求助] 请教xrun的多核模式跑后仿遇到的问题
发表于 2019-10-28 10:04:32 | 显示全部楼层 |阅读模式
用xrun的多核模式跑带时序的后仿真,遇到很多很多xmelab的warning(如下所示),跑出来的波形也不对,时序没标上(没有delay)。有大神知道是咋回事吗?非常感谢!1. 跑的时候用的命令选项是xrun -mce -mce_top tb_top.dut
2.用单核模式跑是可以的,没有这么多warning,并且功能正确。
xmelab: *W,SDFINC: The interconnect srctb_top.dut.spare_inst.FE07_fixDrv_01_rough_2_AOI4_MBFF_0710_1_allTviewFE_PDC2579_TIE_01_rough_2_AOI4_MBFF_0710_1_allTview_LTIEHI_88_NET.Ois not connected to the destinationtb_top.dut.spare_inst.fspare_QDFZRSBNM2HCELMX4_23119.RB in instance </proj/netlist/Timing/wcg_cmax.sdf.gz,line 32188302>. The interconnect request will be replaced with a portannotation at the destination.
xmelab:*W,SDFINC: The interconnect srctb_top.dut.spare_inst.FE07_fixDrv_01_rough_2_AOI4_MBFF_0710_1_allTviewFE_PDC3018_TIE_01_rough_2_AOI4_MBFF_0710_1_allTview_LTIEHI_396_NET.Ois not connected to the destinationtb_top.dut.spare_inst.fspare_ND2M2HCERMX6_16470.I1 in instance </proj/netlist/Timing/wcg_cmax.sdf.gz,line 32189318>. The interconnect request will be replaced with a port annotationat the destination.
xmelab:*W,SDFINC: The interconnect srctb_top.dut.spare_inst.FE07_fixDrv_01_rough_2_AOI4_MBFF_0710_1_allTviewFE_PDC76_TIE_01_rough_2_AOI4_MBFF_0710_1_allTview_LTIELO_610_NET.Ois not connected to the destination tb_top.dut.spare_inst.fspare_INVCKCELMX18A_7020.Iin instance </proj/netlist/Timing/wcg_cmax.sdf.gz, line 32189826>. Theinterconnect request will be replaced with a port annotation at the destination.
发表于 2019-11-2 21:35:26 | 显示全部楼层
GMT+8, 2025-12-30 07:26 , Processed in 0.012184 second(s), 4 queries , Gzip On, Redis On.
