查看: 1734|回复: 2
[求助] Calibre LVS Error (Verilog netlisit-GDS Layout)
发表于 2019-10-8 15:17:53 | 显示全部楼层 |阅读模式
Hi, I import a gds2 layout from Innovus to virtuoso (the layout import properly and DRC is Clean). I want to run LVS on this layout with the Verilog netlist (saved in Innovus). I set the v2lvs command parameter carefully and include the StdCell CDL library. LVS run but the result is incorrect. the fill cap cell exists in layout but don't exist in Verilog netlist and exists som incorrect NET. I very try to fix the problem but I can not. please help me. thank you.
发表于 2019-10-21 13:03:54 | 显示全部楼层
Query the fill cap cell is or not in the Verilog netlist
 楼主| 发表于 2019-10-21 14:34:53 | 显示全部楼层
thank you for your help... how could I resolve it?
GMT+8, 2025-12-17 00:10 , Processed in 0.015530 second(s), 3 queries , Gzip On, Redis On.
