楼主: open82977352
求助cadence xcelium1803的破解方法
发表于 2020-3-19 08:33:05 | 显示全部楼层
rifat_rally 发表于 2019-8-23 06:13
Paching method same as previous packages..
License:
### Xcelium
请问怎么找新feature加啊?多谢
发表于 2020-6-2 19:24:22 | 显示全部楼层
Thanks
发表于 2020-7-19 14:59:50 | 显示全部楼层
an anyone explain start to finish what it needs to be done? What I have done:
1. downloaded and installed XCELIUM 1903 base using Iscape.
2. patched installation using patcher (./cadence.sh <path_to_xcelium.../XCELIUM1903>
3 . generated license file using the generator in this topic in windows and then copied license.dat in a linux location and pointed env variable LM_LICENSE_FILE to the path <><path_to_license.../license.dat>
When run a simulation using xrun I get the following:
Trying to check out license... Xcelium_Limited_Single_Core 19.00-Failed Xcelium_Single_Core 19.00-Failed Xcelium_Safety 19.00-Failed Xcelium_Multi_Core 19.00-Failed Xcelium_For_Partners 19.00-Failedxmsim: *F,NOLICN: Unable to checkout license for the simulation.
What am I doing wrong/missing?
发表于 2020-10-19 22:59:01 | 显示全部楼层
这个还能用么
发表于 2022-6-21 11:07:49 | 显示全部楼层
License:
### Xcelium
这个管用,直接就复制粘贴到license.dat的最后就可以使用,如果还需要添加其他的FEATURE,把FEATURE后面的名字改一下就可以了
发表于 2022-7-22 20:53:53 | 显示全部楼层
goodd
发表于 2023-12-27 08:45:16 | 显示全部楼层
多谢多谢
发表于 2024-3-28 00:42:12 | 显示全部楼层
非常感谢
GMT+8, 2025-12-25 17:15 , Processed in 0.047024 second(s), 5 queries , Gzip On, Redis On.
