楼主: open-CAD
EDA patch 那些事儿~
 楼主| 发表于 2019-9-4 23:45:45 | 显示全部楼层
风向仪 发表于 2019-8-28 16:59
大哥大哥,我用你那个patch.sh脚本,报错:[/img]不能访问路径。是因为系统环境吗 ...
抱歉,没注意到你的回复。请在1patch后加上你的需要patch的软件安装目录
 楼主| 发表于 2019-9-4 23:47:15 | 显示全部楼层
glzhiyu 发表于 2019-9-4 22:49
我测试了下,在vmanager1903上patch后,还是提示license版本不对,无法使用,估计是java 的patch不彻底所致 ...
能否附上相关信息?有可能是相关库缺失~
发表于 2019-9-5 10:20:40 | 显示全部楼层
大神,感谢分享
发表于 2019-9-5 14:19:13 | 显示全部楼层
MARKIT!
发表于 2019-9-5 19:26:03 | 显示全部楼层
Appreciate your expertise. Look forward to the Syn patch version.
发表于 2019-9-5 23:15:19 | 显示全部楼层
open-CAD 发表于 2019-9-4 23:47
能否附上相关信息?有可能是相关库缺失~
1.
2.
4.配置启动vmanager server
5.启动server提示:
ERROR: Server not started:
Failed Acquiring Required License - The server capabilities exceeds the licenses available - Failed to acquire bundle PROJECT_SERVER features sequence is: [VMG100-[vmanager_project:19.0], VMG200-[vmanager_integration:19.0]], last message was Failed - (LMF-03506): License call failed for feature vmanager_integration, version 19.0 and quantity 1. The license server search path is defined as 5280@bbu001. The FLEXnet error message is as follows, - FLEXnet ERROR(-506, 1022, 0): Internal Flexlm Error (-506,1022)  -  - Run 'lic_error LMF-03506' for more information.
Stopping server
发表于 2019-9-10 20:27:23 | 显示全部楼层
thanks~
发表于 2019-9-16 16:40:56 | 显示全部楼层
非常感谢!
发表于 2019-9-16 16:54:25 | 显示全部楼层
Thanks for sharing
发表于 2019-9-18 16:14:53 来自手机 | 显示全部楼层
谢谢大佬
GMT+8, 2025-12-18 18:39 , Processed in 0.040125 second(s), 3 queries , Gzip On, Redis On.
