请问ads2017使用momentum仿真时总是报这个错是为什么?报错结果如下:
License checkout took 0.147 sec
License checkout took 0.010 sec
Momentum MomEngine_64 12.61.024 (*) built: Jan 11 2018
Copyright 1999 - 2017 Keysight Technologies
Simulation started on: Sat Jul 27 22:24:50 2019
Simulation Mode: RF
--- ERROR ---------------------------------------------------------------------
Tech Input proj.tch - line 1 : syntax error, unexpected TEXT, expecting UNITS.
Is VERSION a valid keyword and correctly spelled ?
The tech file should contain 3 blocks of data:
* the units definition, starting with the token UNITS
* the stack definition, starting with the token BEGIN_STACK
* the masks definition, starting with the token BEGIN_MASK
Unable to open the file proj.sub.
Check : - existence of file ;
- file/directory read access permissions.
Unable to open the file proj.lmp.
